Transmission broke
Don't want to be th bringer of bad tidings.....
https://rennlist.com/forums/928-foru...-any-gear.html
https://rennlist.com/forums/928-foru...n-picture.html
After my experience i'd say go for a used known good box (if there is such a thing as known good)
I gotta agree.. would be very rare case if one of these transmissions failed. I would check the torque tube or torque converter. I have seen these cars with 300k on them with the original transmission there pretty bullet proof if fluid changes are done every once in a while. I have a 87 trans for $650 plus shipping. Your more than welcome to drive the car before I pull it out. Miles are 110k currently. I'm upgrading to a LSD unit is the reason for the swap.
My mechanic is going to France next week and has no time to pull the box.
We'll see what the story is on his return.
I see some used trans on ebay so I'll probably buy one of them if needed.
Oklahoma Foreign, Los Angeles Auto Parts, 928 World Wide Parts are the sellers.
The ad from 928 WWP is is thought provoking to say the least. The caption is 928 Transmissions '89 Open and shows a picture of one on it's side with the pan off - everything open to the elements. At first I thought they meant an open diff - now I'm not so sure.
http://cgi.ebay.com/ebaymotors/Porsc...ehicleQ5fParts
At least it's early in the season...
Captain Obvious
Super User
Super User
Let me ask again. When you put it in P (park), did the car stopped rolling? Your original post does say. Did Park work? Also, did your mechanic check the shifter linkage at the transmission?
