The color match is decent. I guess it looks better then before. Did you use rattle can paint? Or did you actually get some stuff you had to spray with a gun?
You didn't put enough clear on it.
It was all rattle can. I'll put a few more coats of clear coat on after a few more days.
Well done, now search the internet for wet sanding. You are going to have to let the paint sit baking in the sun for a few more days then hit it with some wet sanding and it will start to shine up like the hood. This will also get rid off the orange peal look.
Give it a try.
Check out Eastwood for supplies
Thanks for the input. What grit wet/dry sand paper are you talking about? Would I need to repaint/clear coat after the sanding? Or is the sand paper grit light enough to just bring out the luster? As you can tell it's my first time doing anything like this.
2000 grit paper, then use some 3M product, I think its called perfect-it 3000, and a buffer. I use terry cloth first for a rough polish, then use the special foam pads you get from 3M for a final polish. The wet sanding is just to bring the paint finish to an even smooth layer, then you polish the sanding scratches out. Look up "color sanding" on google, there are some good links with pics on how to go about doing it.
Im thinking of doing the same thing. did you use just rattle cans, paint and primer, or did you spray the final coats with a spray gun. looks good, but hard to tell from the pics.
