928 Forum 1978-1995
Sponsored by: 928 Specialists
How to replace the cabin temperature sensor?
Old Apr 22, 2010 | 04:31 PM
SQLGuy's Avatar
SQLGuy
Default How to replace the cabin temperature sensor?
Hi folks,
Just wondering what's involved in replacing the HVAC inside temperature sensor on the console. Is it neccessary to pull the whole console, or is it possible to reach it from underneath with the PS side console side panel off?
Thanks,
Paul
Old Apr 22, 2010 | 04:47 PM
danglerb's Avatar
danglerb
It does NOT pry off.
Official way is dash R&R, but I think some have gone in through the glovebox?
https://rennlist.com/forums/928-foru...mp-sensor.html
Old Apr 22, 2010 | 05:00 PM
SQLGuy's Avatar
SQLGuy
Thanks.
I know it doesn't pry off, but, unfortunately, someone who had access to the car in the past did not know that!
Oh well, I guess I'll combine it with shift bushing and shifter foam work I've got queued up...
Cheers,
Paul
Old Apr 22, 2010 | 05:06 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
Dash does not have to come out. Just the center console needs to be removed.
Old Apr 22, 2010 | 06:46 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
you cant get to it from the inside the glovebox either
Old Apr 22, 2010 | 07:38 PM
StratfordShark's Avatar
StratfordShark
Replaced mine recently which required centre console removal, after which it's easy to work inside on removing the faulty sensor and installing replacement.
Things line up better when you replace console if you first install the two bolts which hold the console at top of centre vent.
Have a grabber or magnetic pick-up handy for the "hidden" glovebox bolt which lives behind grommet.
File Type: jpg
Old Apr 23, 2010 | 12:45 PM
Espritman's Avatar
Espritman
Too many of us have discovered that it does not pry off. Seems to me I've read that there's an aftermarket replacement 'grill cap' installed from the outside if that's all you need. Anyone know the details?
If not, how much $$ is the sensor unit? I gotta' do it too.
Bob
'88 S4
Old Apr 23, 2010 | 12:54 PM
SQLGuy's Avatar
SQLGuy
Bob
'88 S4
The sensor is about $80 new from the typical good sources. The cap is about $40, depending on material.
I got a used sensor from eBay for reasonably cheap money.
Old Apr 23, 2010 | 01:11 PM
Calgary Ole's Avatar
Calgary Ole
Bob
'88 S4
Nichole from Hooked on Cars has the stick on covers or if you are here in Canada, Jaeger is the maker. I have a brushed aluminum cover that looks very nice and I can post a pic this afternoon when I get home if anybody wants to see.
Old Apr 23, 2010 | 01:17 PM
mcholdfast's Avatar
mcholdfast
There's a couple of vacuum actuators, footwell and comb flap, that will be easy access while you've got the console out. You may want to consider replacing or at least checking these while you're in there. It seems that the bladder in the footwell actuator is always the first to go.
Old Apr 23, 2010 | 01:51 PM
WallyP's Avatar
WallyP
Rennlist Site Sponsor
"It seems that the bladder in the footwell actuator is always the first to go."
Nope - comb flap actuator diaphragm (orange line) is usually first...
Old Apr 23, 2010 | 02:00 PM
mcholdfast's Avatar
mcholdfast
You would know better than I but I've had three and know of one other with bad footwell bladders when all the rest were OK.
Sorry to the OP for the hijack.
Old Apr 23, 2010 | 06:27 PM
Calgary Ole
Pic of the cover for those who have damage. Comes in different colors and materials
File Type: jpg
Old May 29, 2010 | 10:00 AM
FREAKINHEAT's Avatar
FREAKINHEAT
Calgary Ole, Do you a photo of the sensor from the side? I wanted to see the profile shot of it to see how high it sticks out. How does it stay in place by the way? Thanks.
Old May 29, 2010 | 12:56 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
The aluminum one is very thin and painted flat black is hard to tell from stock.
