928 Forum 1978-1995
Sponsored by: 928 Specialists
Twin Turbo 928 fixed and back out there terrorizing the streets!
Old 11-12-2020, 04:33 PM
  #2566
john gill
john gill's Avatar
Thats a trip to the wiring diagram , will have a look later when I am in the workshop
Old 11-12-2020, 11:43 PM
  #2567
ptuomov
ptuomov's Avatar
Let's see how much damage I can do to the body (of the car) tomorrow at lunch.
Originally Posted by Strosek Ultra
Using a die grinder you can enlarge the hole in the sheet metal. I am sure you will be able to find a larger 25mm grommet that will fit.
Åke
Old 11-13-2020, 01:09 AM
  #2568
Lizard928
Lizard928's Avatar
The AC is separate but does send a signal to the computer to raise the idle.
The LSU4.9 plug will not fit through the floor and the sensor itself cannot be depinned. You have to run the connector under the car and just run the wiring through the hole. I have yet to have any have corrosion issues this way.
I use the Innovate Digital MTX-L as the wiring that connects the WB controller/gauge fits through the floor without any issues or modifications required.
Old 11-13-2020, 04:03 AM
  #2569
Strosek Ultra
Strosek Ultra's Avatar
Take it easy and you will do a good job. Deburr the edges and put on some paint to avoid corrosion.
Åke
Old 11-13-2020, 08:29 AM
  #2570
ptuomov
ptuomov's Avatar
Does the A/C clutch stay always engaged when the A/C button is on? If so, the A/C compressor is getting a workout with the engine rpm fluctuating between 4000 and 8000 within an instant.
My preference is to expose as little of the sensor wires/loom and connectors to the under car elements, including exhaust heat. Because of this, I’m leaning towards making the hole bigger (1”) and having all those inside the car. With 1” hole, I believe the exhaust sensor can be pushed out from inside the car, even if one wire is already going thru the hole.
Old 11-13-2020, 08:38 AM
  #2571
Thom
Thom's Avatar
In any case I would leave the connector outside, for the ease of replacement. Never had an issue with mine located over the torque tube just behind the bellhousing, and it's getting a lot of heat there (944T).
Old 11-13-2020, 08:41 AM
  #2572
Strosek Ultra
I think the AC clutch is always engaged when the button is on. If the pressure in the system is too low, the magnetic clutch never engages. Do you need A / C at this time of year?
You can always drive with the side window open, but it increases air resistance and reduces top speed.
Åke
Old 11-13-2020, 09:06 AM
  #2573
ptuomov
ptuomov's Avatar
Does the A/C clutch stay always engaged when the A/C button is on? If so, the A/C compressor is getting a workout with the engine rpm fluctuating between 4000 and 8000 within an instant,
Åke
American street cars by the definition of an American street car have working air conditioning.
What would the top speed even be with G28.13 on fifth gear and the peak power rpm at about 7250rpm and redline at 8000rpm? I’m thinking that opening the window or sunroof at that speed might cause problems bigger than a reduction in top speed.
Old 11-13-2020, 10:28 AM
  #2574
Strosek Ultra
Cool
What would the top speed even be with G28.12 on fifth gear and the peak power rpm at about 7250rpm and redline at 8000rpm? I’m thinking that opening the window or sunroof at that speed might cause problems bigger than a reduction in top speed.
It is a German Super-Sportwagen on an American road. An open window increases the noise level in the car, which can be remedied with various technical solutions.
Keep in mind that an engaged A/C compressor reduces the power at the rear wheels, which also reduces the top speed of the car probably by about one mph.
Åke
Old 11-13-2020, 12:31 PM
  #2575
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,704 Likes on 1,308 Posts
You have G28.13s, no? Here's an amateur photoshop of the speeds in gears graph for G28.13, extended out to 8000 rpm. It's 33.5 mph per 1000, or 268 mph at 8000 mph.
A Euro G28.12 would be 28 mph per 1000, or 224 mph at 8K.
Old 11-13-2020, 12:32 PM
  #2576
Rob Edwards
Archive Gatekeeper
Hey, you can do 0-60 pulls in 1st gear.
Old 11-13-2020, 01:00 PM
  #2577
ptuomov
ptuomov's Avatar
Haven't even done a hard standing start yet.
Have done some pretty fast 55 mph to 90 mpth moves on the highway.
Old 11-13-2020, 01:45 PM
  #2578
Strosek Ultra
A rough calculation tells me that the 928 engine power needs be appr. 750 HP for a top speed of 225 mph and that is if Tuomo is driving with the windows closed.
Åke
Old 11-13-2020, 02:34 PM
  #2579
ptuomov
ptuomov's Avatar
Åke
It makes more than 750hp at the crank at those rpms, so it should get there if anyone is crazy enough to ever try.
On the "drill baby drill" project, there's now round 1" diameter hole there slightly offset from the original location. I had a wooden staff on the other side pressing against the hole such that I could locate pilot slightly offset away from the turbo speed sensor hole. I deburred the hole first, then smoothed the edge with a stone on a drill briefly. You can run a finger over the edge without getting feeling it rough. The oxygen sensor now fits thru, barely but it fits. I added some rust proofing there as well on the bare metal, what looks like burrs in the photos is in fact just the rust proofing substance. That was my lunch hour right there, back to the regularly scheduled programming...
Old 11-14-2020, 04:42 AM
  #2580
john gill
john gill's Avatar
According to the standard wiring diagram the clutch solenoid is disengaged at wot , obviously the factory didnt expect you to have the pedal floored constantly
Quick Reply: Twin Turbo 928 fixed and back out there terrorizing the streets!
