Twin Turbo 928 fixed and back out there terrorizing the streets!
#1576
Logically speaking, without piston squirters, it would seem to be a bad thing to keep the pistons from some or all of the oil spraying around from the crank. Obviously windage affects many things. But if you stop and think, keeping some of the oil off the crank throws (drainback control) is good- but keeping most of the oil off the crank (scraping) could be bad for piston tempature.
At least with the stock S4 pistons and stock width rings running on a stock open-deck Alusil cylinder towers, the thermal inertia and heat flow capacity are very high. Piston cooling doesn't seem to be a high priority compared to dealing with all that excess oil everywhere. If you're concerned about cooling, a much higher priority item would be to figure out how to get more air flow thru the radiator. The stock bottom end doesn't seem to have any problems getting the heat into the coolant.
After thinking about is for a couple of years, I'm not surprised that the factory eliminated the squirters ftom S4 early during the first production year. Now, if you go to 350g pistons with razor-blade rings running steel sleeves, and four stage dry sump pulling 20 inches of vacuum in the crankcase, then maybe it's a different tradeoff. Maybe you do want to wire-EDM the rods for wrist-pin lubrication and to add piston oil squirters. At this point, I know of exactly one engine that even remotely resembles that.
#1577
However in a lower RPM turbo application the benefits of cooling underside of piston crown and wrist pin would outweigh disadvantage of resulting excess windage from absence of oil control measures.
#1578
1 Post
Nah, You use piston squirters to cool pistons. The fug floating around inside a crankcase does nothing to cool pistons, best to get rid of it to ease the job of the oil control rings.
As noted by Tuomo the alusil block transfers heat to the coolant very well.
#1579
In my opinion, the 928 S4 has a big problem of spraying too much oil to the pistons and bore walls. All efforts should be taken to reduce the amount of oil spraying all over the place in that crankcase. These include rings better suited to removing oil from the bore walls, increased pan volume with a spacer, pumped vacuum in the crankcase or at least a good breather system, baffling for the oil sump, limiting rpms, and various devices to manage the piston pumping pulses, etc. Personally, I believe that with a mildly-modified stock bottom end with its wet sump and all, you can't remove too much oil from the bore walls and the pistons.
AGREED
AGREED
AGREED
AGREED
Compounded in case of steel liners the added resistance to heat conduction would likely raise piston temperatures to point of cooking oil in lands, resulting carbon build up from high top land temps would perhaps lower pre-ignition threshold in a high specific output turbo motor.
It would be most beneficial to employ piston squirters in that scenario to provide an additional heat path for cooling piston crown resulting in lower top land temps as well.
Goes without saying oil windage control needs to be optimally applied commensurate with intended rpm range as well.
Not sure about benefits of wire-EDM oil feed passage to wrist pin in case of piston squirter being employed.
Mike I trust executed this in expert fashion mitigating risk of introducing stress risers when passage runs to close to surface (challenging when dealing with rod beam limited cross sectional area).
The net cost vs. benefit may not make this the route to take.
#1580
was building a case for using piston squirters and instead controlling the resulting additional "fug"
#1581
Supercharged
Interesting Knock Run data. I found the the 2/6 (but mainly 2) tends to knock more often than others especially at that 3500-4000 transition to the upper RPMs. Kind of a low level errant knock, and it appears yours does too. I've tried many things to get rid of that, but I think its either a false positive, or just something else in the overall design of the motor. But you certainly seem to have a bit too much advance from about 5k up.
I need to look at the new ST2 SW and see if it makes sense to tweak my GT... Now that I think about it, It's been way too long since I've driven that thing. Hmmm...
#1582
Rainman
consider that the 944 turbo was produced for 5 years and never had squirters even at 100hp/L (1988 turbo S and 1989-91 standard turbo).
as i recall the only piston ring set currently available for purchase is "944 turbo spec" even for the 928 engines so those rings must be pretty good at de-oiling a wall.
on the four-bangers they didn't have squirters until the 968 in 1992. i think that was due to the big piston being very thin in the middle section to keep weight down, so they needed to control piston temperature better.
even today most of the "big builds" approaching or even exceeding 200hp/L don't use squirters, just big oil coolers with stock radiators.
#1583
Similar to a turbo engine, with a normally aspirated motor with stock exhaust manifolds, I'd expect to see the 1&6 knocking at high rpms. A normally aspirated engine with headers, I wouldn't expect to see that.
The mid range 4000-6000 rpm knocks that happen between the low rpms (where the 180-degree exhaust blowdown interference causes knocks) and the high rpms (where the 90-degree exhaust blowdown interference causes knocks) are due to some cylinders filling better than others due to the intake manifold design. It's the long runners that are straight that fill the best, and they also knock the most in the mid range rpms.
Reading too many books and looking at too much sensor data has caused me to believe that "things happen for a reason". ;-)
The knocks in that graph were induced intentionally and the knock retard left on to see what cylinders knock at what rpms. It will not knock in the tune we actually run.
#1584
Inventor
Inventor
Just a touch to bring the flow rate of the straightest runners closer to the kurvy runners.
Or:![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Or:
![](https://lh5.googleusercontent.com/-Zf9KYKVy-eY/TrhUaB5UaOI/AAAAAAAAA5Y/ZtfMQPNQryc/s645/Varintake.jpg)
#1587
One could make more power either with cylinder specific ignition trim and/or with a fabricated intake manifold. Right now, it's a bit of an experiment how far the stock computers and the stock intake manifold can go. I'm just curious what's the limit for those, so we might see.
#1589
For the mid-range rpm knock that is not caused by exhaust but instead by some cylinders having better filling intake runners, fueling and ignition trims both would be useful.
In my case, however, that mid-range imbalance problem isn't nearly as consequential as the high-rpm imbalance problem, so cylinder-specific ignition trim would be a higher priority than cylinder-specific fuel trim.
#1590
Inventor
^^^^ that is a great summation.
Individual cylinder fuel trim would be nifty, but I'm not sure it would do more than be more efficient (at least N/A). Too bad, because I was just visualizing how to program a dual batch fire, using the vapor recovery solenoid output, to fuel some cylinders (EG. inner/outer) at a different rate.
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
