928 Forum 1978-1995
Sponsored by: 928 Specialists
Twin Turbo 928 fixed and back out there terrorizing the streets!
Old 02-16-2017, 08:19 AM
  #1516
bertram928
bertram928's Avatar
for those applications that are limited by turbo frame size (not cost) yet want the highest possible mass trough-put and efficiency per turbine wheel and compressor wheel size; these are the guys i recommend:
http://www.extreme-tuners.com
http://www.extreme-tuners.com/catnav...&id=285#anchor
Old 02-16-2017, 09:11 AM
  #1517
ptuomov
ptuomov's Avatar
Originally Posted by 333pg333
Lols...Riiight. Just don't know with some of you extreme 928 guys. You do it a bit differently than us but no less thorough and impressive.
I take pride in how little we've had to do. Part of the reason why we haven't had to modify much is that we read books and run the computer a lot to understand what is necessary to modify. Some testing in the end is of course necessary, for example, we've spent a lot of time validating the 1D simulation model we have.
Still think you should investigate those EFR turbos. Even out of curiosity.
John had those at his shop and there's no way to make them fit. They are really long. If you have space, though, those are cost effective solutions from the overall system perspective as they integrate everything from bypass valves to wastegates to speed sensors.
Originally Posted by bertram928
for those applications that are limited by turbo frame size (not cost) yet want the highest possible mass trough-put and efficiency per turbine wheel and compressor wheel size; these are the guys i recommend: http://www.extreme-tuners.com/catnav...&id=285#anchor
We're not at the limit with this turbine housing yet. There would even be one larger A/R housing available. And the latest top of the line Garrett wheels are in my opinion pretty damn good. If we ever run out of size with these new SS housings, though, then we'll have to think of something else. The current set-up flows a lot, fortunately.
Old 02-16-2017, 05:25 PM
  #1518
Roy928tt
Roy928tt's Avatar
Right...so this is an entirely open ended pursuit of horsepower? As long as the long motor consists of factory components. No stopping when you reach a 4 digit output ?
Old 02-16-2017, 08:49 PM
  #1519
333pg333
333pg333's Avatar
That looks intere$ting!!
Old 02-19-2017, 09:05 PM
  #1520
ptuomov
ptuomov's Avatar
Default The 700hp system going on another car
Here's another car getting the 700hp system that my black car used to have:
Old 02-19-2017, 10:22 PM
  #1521
ptuomov
ptuomov's Avatar
Default A declaration
I hereby declare that the 80 lbs injectors can idle with the stock computers and the sharktuner.
Old 02-19-2017, 10:39 PM
  #1522
Tony
Tony's Avatar
sharktuner rulz!
Old 02-20-2017, 04:46 AM
  #1523
Strosek Ultra
Strosek Ultra's Avatar
Good to know.
Åke
Old 02-20-2017, 09:22 PM
  #1524
ptuomov
ptuomov's Avatar
Default And, yes,...
We needz more thermocouples.
These are now bonded to plugs that can be screwed to the existing ports.
Old 02-22-2017, 10:51 PM
  #1525
bertram928
bertram928's Avatar
Ptuomov: to quote your post #1517:
"And the latest top of the line Garrett wheels are in my opinion pretty damn good"
https://m.facebook.com/story.php?sto...74241639280638
These guys agree with you 100%
per comment section:
"Garrett turbos are the highest quality off the shelf turbos can buy"
Old 02-23-2017, 12:52 AM
  #1526
V2Rocket
Rainman
V2Rocket's Avatar
Have read a lot of this thread but haven't seen mention (or just missed it) of whether you are using stock connecting rods in this beast?
This is a standard S4 engine otherwise right?
Old 02-23-2017, 06:25 AM
  #1527
ptuomov
ptuomov's Avatar
Stock PPF rods, not the later cast ones, in all their about 850g glory!
In my opinion, those rods and the whole rotating assembly can take very high compression loads, much higher than most aftermarket "H-beam" rods. High rpms, not so much... The stock pistons with the machined dish weight about 610g and the wrist pins about 180g each, making the total weight almost 800g. That 800g slug is laughing at the compression pressures that we've shown it, but the rod would be "huffing and puffing" at the stock GT redline.
It's an engine that has mostly stock components, but many of them are thoughtfully modified to work together and everything is assembled together very carefully. It's got street cams that however are a little bigger than the GT cams, and lower static compression for forced induction, for example. I think those Elgin 65-6 cams are still the best street cam profiles ever made for the 928 S4/GT/GTS. Everyone who's ever installed them and then sorted out the tune has been real happy with the result.
Old 02-23-2017, 08:54 AM
  #1528
Dave928S
Dave928S's Avatar
Ah ... I now understand why you can have such confidence in that motor
Old 02-23-2017, 09:45 AM
  #1529
ptuomov
ptuomov's Avatar
Originally Posted by Tony
sharktuner rulz!
It does. It's great that they at JDS are providing us this interface to modify the LH and EZ-K parameters.
As we're going where not many (any?) have gone before, there are always new things to solve. Currently, John's documenting what looks like a minor bug in the ST's idle warm-up algorithm for very large injectors. The car runs fine, but we're trying to get all the ducks in the row perfectly.
These guys agree with you 100% per comment section:
I think that anyone who understands these turbos knows that Garrett design engineers (not talking about the tech support here) are top notch and have recently been spending time coming up with new and even better wheels for various applications.
The same builder built a similarly very "stock-like" and conservative engine for George Suennen that has held up very well under extended high-load and high-boost runs with a supercharger when more "exotically" modified engines are going !kabloom! left and right.
This blue engine, for example, gives only 2 CFM of blow-by at 5000 rpm, 10 psi of boost, and over 450 ft-lb of torque. By my logic, this measurement tells us that a lot went right and very little went wrong when the engine was built...
Old 02-23-2017, 10:44 AM
  #1530
V2Rocket
Rainman
V2Rocket's Avatar
hard to tell in the photos...do your rods look like this? (944 turbo forged)
OR...
here is 84+ 944 cast rod (top) compared to 82-83 944 "sintered" PPF rod (bottom)...is yours like this one?
Quick Reply: Twin Turbo 928 fixed and back out there terrorizing the streets!
