928 Forum 1978-1995
Sponsored by: 928 Specialists
Full size spare - which size rim to use?
Old 03-07-2010, 07:36 PM
damonoresky
damonoresky's Avatar
Default Full size spare - which size rim to use?
Thanks to a fellow Rennlister (George you are awesome!) I now have a spare set of D90 rims for my '91 S4. Since I have spares now which size rim is better to use on either the front or rear for a spare, the 7.5 or the 9?
Old 03-07-2010, 07:42 PM
UncleMaz
UncleMaz's Avatar
I stuck a 9 inch rim sans tire in my spare tire well and it stuck a good 2-3 inches above the shelf. It was a Cup 1 wheel if that makes a difference.
Old 03-07-2010, 07:44 PM
RKD in OKC
RKD in OKC's Avatar
Where in the car are you going to put a full size spare?
Old 03-07-2010, 08:30 PM
Landseer
Landseer's Avatar
Old 03-07-2010, 09:02 PM
damonoresky
A full size tire will fit in the cargo area, although it will take up about 1/2 of it.
What I am really asking is the 9" too big for the front or the 7.5" too small for the rear? I guess for a short time it doesn't really make much of a difference?
Old 03-07-2010, 09:07 PM
jpNcos
jpNcos's Avatar
You will be fine for an emergency and it will save a little room,
Old 03-07-2010, 09:21 PM
Jim M.
Jim M.'s Avatar
If your going to put the full size spare in the rear hatch area, be sure to weld a bolt down assembly to hold it down during any accident or panic stop. You don't want it taking your head off as it continues forward at your original speed.
Old 03-07-2010, 09:22 PM
pcar928fan
pcar928fan's Avatar
How often do you have a tire go flat on you?! I don't think it has EVER happened to me in any of my 928's...well, ok, that is not true. I have picked up a nail, a screw and had a bad valve stem once but NONE of them required a road side tire change!
Old 03-07-2010, 09:39 PM
JHowell37
JHowell37's Avatar
Knock on wood.
I refrain from even thinking about flat tires while driving, and never ponder "my luck" at not having to do a roadside tire change.
Old 03-07-2010, 09:52 PM
pcar928fan
pcar928fan's Avatar
Yea, I jinxed the crap out of myself w/ that post didn't I?!
Old 03-07-2010, 09:53 PM
damonoresky
If I have a spare I'll never get a flat. If I don't carry one I'm sure to get one on the first day of a 3 day weekend in Napa 100 miles from home with an angry wife.
I'd rather be prepared!
Old 03-07-2010, 10:02 PM
pcar928fan
pcar928fan's Avatar
What is wrong w/ the regular spare? They actually work really well! I have seen one go about 1000 miles I think it was! I don't recommend that, but they are not bad!
Old 03-07-2010, 10:11 PM
damonoresky
I just can't picture running a 928 with that mini blow up tire, especially when you have other options like I do now!
Old 03-07-2010, 10:18 PM
pcar928fan
pcar928fan's Avatar
Actually it is a full size wheel and tire... Blow up tire and ugly presses steel wheels, but full size. You do have other options though for sure!
Old 03-07-2010, 10:39 PM
borland
borland's Avatar
I once worked with a guy that was in a habit of carrying his bowling ball in the back seat. One night he was out drinking and driving.
Long story short, when he misjudged a curve and rolled the car on the freeway, the bowling ball did a number on him. After several months of convalescent care he was back at work.
Quick Reply: Full size spare - which size rim to use?
