Knock Sensor
Greg at Precision told me my knock sensor was not functioning (taped up and out of the way is how he put it). What is this downside to this. I only run 92 Octane, drive like an old lady (cept when I mashed it and throttle stuck open).
Am I missing out on power. My car kind of feels doggy.
Thanks,
Thanks,
Check this link (thread started by Red Shark 1990 April 2008)
https://rennlist.com/forums/showthre...ferrerid=63671
Getting the timing right will make a world of difference. (So I've been told)!
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Former Sponsor
Thanks,
Thanks,
Okay so I found the front knock sensor and the connector is all gone. just three pins. i took the loose pins out. deox'd them and put heat shrink tubing around them so they don't touch whilst in the plug. I imagine after looking at the WSM you need to take the intake off to do this so I don't think I'll be doing this tonight or this weekend. As the pins were just plugged in the connector I hope they were in the right way. I'll try to figure it out from the WSM but that's not my strong point. I can wrench anything apart and reassemble it. Electronic diagnosis, not so much.
Anyone know off the top of their head what pin/color wire connects to what on the front knock sensor? Also, without a hammer will I just know it works cause the car goes faster now? I never hear any knock on 91 octane
Chronic Tool Dropper
Jeff, with the sensor disabled/malfunctioning, the EZK retards the ignition timing as if it was hearing knocks. The fact that you don't hear knocking is not any indication of the condition of the sensor.
Yep when I was in for my PPI. Its a good thing, just took me 4 months to remember you said that when I was out there.
I am not saying you told me not to do or not do anything beyond that. I stated it because I was asking people what I could be a reason my car feels kind of sluggish. Your telling me it was taped up was what prompted me to go look at it as a possible source for the dogginess. If you hadn't told me this as part of the PPI I wouldn't have even thought of it.
Now I can do an intake rebuild and fix them while I am at it.
The oil cooler was the other thing. If you hadn't seen that, I could have been stranded in bumblefart who knows where on my drive home.
So once again your very thorough PPI has come through for me.
Thanks. Any other shop that just fixes cars in general wouldn't have noticed these things. Your experience even has delayed results!
Jeff, with some of the old threads you've dug up here, that you haven't hit at least one on the relationship between the knock sensors / Hall Sensor/ and even the crank sensor. I'm redoing all as the WYAIT bug bit with the intake off.
Getting the timing right will make a world of difference. (So I've been told)!![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
I run three businesses and my brain is full most of the time so it takes a while for some of this stuff to find the proper home.
If you've reconnected the kock sensor, then just do a battery disconnect to clear the fault code and then a test drive. The car should then have recovered.....
Thanks John. I did not know to do that. I'll try it at lunch time and see how the drive goes one way vs the other.
