New to the forum. I have a 928 jet car...
#46
On the exhuast issue: the exhaust comes out of that stack at over 400mph. The only time the exhaust would be an issue is if I could get fast enought to match that speed (which I will not) and the other issue is during a very cold day, you'ld be able to see the heat signature coming out of the stack :-)
#48
Big Mike
#50
Welcome, great project there Mike. I'm sure you would be most welcome at the next Sharktoberfest, an annual 928 get-together held every October in Anaheim, should you care to stop by.
BTW, given your "horn hobby" I'm not surprised your User ID is shouting...
#51
#52
That's not stock, is it?
Welcome, Big Mike - ya crazy bastid.
I bet your neighbors love you.
What's the dB output of this monster NASA Horn?
http://www.youtube.com/watch?v=6Maso...eature=channel
#53
#55
Funny, my wife came into our study, where I was watching the video, holding her ears asking what that noise was. I didn't think it was that loud, but that jet noise really carries... and annoys...
#56
There is some lag at start up, but if you load the torque converter, lag in not felt. You can maintain the vehicle at any speed, no need for trottle modulation.
#57
#58
Cottage Industry Sponsor
That is the craziest 928 project I've ever seen or heard of.
I always imagined them as being sluggish because it takes time to spool-up, but looking at your video, it seems the automatic makes-up for that.
Could you manually shift down when you are braking, so that the turbine is allowed to rev higher?
Finally a solution that will make windshield wipers obsolete. I've been waiting for that for years.
Maybe it can defrost at the same time. Not in SoCal, but our frieinds in colder climates may appreciate the idea.
#59
Basic Site Sponsor
Basic Site Sponsor
Crazy cool.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
#60
SPL @ 1METER (3.28') is 162.68. SPL @ 500 feet is 118.92 @ 100Hz.
This test was done using 250psi (minimum air pressure) not 500psi (ideal working air pressure) in an attempt to see if the Hz would change at lower pressure.
More about the "N.A.S.A" horn:
this is a reverberant chamber horn used by NASA. Reverberant chamber is unique to NASA and the USAF for testing full-size aerospace components at high levels of sound pressure.
The noise in the chambers can be shaped to match the specifications of space shuttle and rocket launches, aircraft structural excitation, engine nacelle noise, unsteady turbulent airflows, and the acoustic test specifications required for military equipment sold on domestic and export markets. This flexibility has made it possible for to test satellites, satellite payload equipment, airframes, and aircraft components . Simply put, there is a enclosed room with this horn's opening bolted to the wall with the opening of the horn facing in. They would place the object they would want to test in that room, seal it up, and fire up this monster for a given lenght of time to see if it can handle the extreme low harmonics from this horn. The only problem is, the walls also started falling apart.
This horn has a working pressure between 250-500psi. The squealing at the begining of each honk is normal. There is an exhaust port at the back of the power chamber housing to allow the titanium and tungsten diaphragm to vibrate at high pressure supply). This horn is 7' 5" long, and is 282lbs. This horn is no longer in used because (and is belived to be the only one that has survied the scrap yard). The mortar of the test building started coming apart from the testing that was done over the years.
