Did I lose them, or: I never had them?
Archive Gatekeeper
For posterity, here are the contents of the '87-91 engine seal kit:
Engine gasket set: 928.100.901.03
SET INCLUDES
valve stem seal 'condoms' 000.043.204.45
temp I seal 900.123.007.30
cam tensioner banjo bolt crush washers 900.123.050.30
block drain plug crush washer 900.123.055.30
oil pump compression spring sealing ring- above oil lines on block 900.123.060.30
? 900.123.115.30
oil drain crush ring 900.123.118.30
oil oressure sealing ring 900.123.143.70
Lower 12 sealing rings under cam cover bolts 900.123.144.30
radiator sealing ring 900.123.149.70
dipstick o-ring 900.174.044.40
oil pan gasket - cork 928.101.207.00
head gasket 1-4 928.104.367.05
head gasket 5-8 928.104.368.05
spark plug sealing rings 928.104.443.08
valve cover gasket 928.104.447.09
valve stem seals 928.104.601.07
rear cam plug 928.105.215.00
cam pins 928.105.262.00
cam belt tensioner to block gasket 928.105.611.05
water pump gasket 928.106.134.05
coolant cover gasket - 87 only, don't need 928.106.167.01
coolant crossover end gaskets 928.106.227.00
oil pump pickup sealing ring 928.107.136.04
oilpan drainback tube cover seal- don't need 928.107.169.01
oil filler neck bottom gasket 928.107.307.00
air cleaner housing to MAF hose 928.110.132.00
intake runners to block gasket 928.110.580.02
throttle body to intake gasket 928.110.637.02
rubber thrust rings under intake bolts 928.110.694.01
right side intake manifold side cover gasket 928.110.713.01
left side intake manifold side cover gasket 928.110.714.01
rear alternator foam seal 928.603.135.03
traingular oil level sensor selaing gasket 928.606.213.03
exhaust manifold sealing rings 944.111.205.00
front crank seal 999.113.263.40
rear main engine seal 999.113.264.40
oil pump shaft seal 999.113.275.40
front camshaft seal 999.113.282.40
base of coolant crossover o-ring 999.701.627.40
thermostat housing o-ring 999.701.632.40
oil pump sealing ring 999.701.633.40
o-rings 999.701.731.40
oil filler cap gasket 999.701.846.40
rear cam sealing ring, for screw plug on back of head N 043 811 1
And the contents of the '92-95 engine seal kit
GTS QUANTITY:
Engine gasket set: 928.100.901.04
SET INCLUDES
valve stem seal 'condoms' 000.043.204.45 2
temp I seal 900.123.007.30 1
cam tensioner banjo bolt crush washers 900.123.050.30 6
block drain plug crush washer 900.123.055.30 1
oil pump compression spring sealing ring- above oil lines on block 900.123.060.30 2
? 900.123.115.30 1
oil drain crush ring 900.123.118.30 1
oil oressure sealing ring 900.123.143.70 1
Lower 12 sealing rings under cam cover bolts 900.123.144.30 12
radiator sealing ring 900.123.149.70 1
dipstick o-ring 900.174.044.40 1
oil pan gasket - cork 928.101.207.00 1
head gasket 1-4 928.104.367.05 1
head gasket 5-8 928.104.368.05 1
spark plug sealing rings 928.104.443.08 8
valve cover gasket 928.104.447.09 2
valve stem seals
rear cam plug 928.105.215.00 6
cam pins 928.105.262.00 5
cam belt tensioner to block gasket 928.105.611.05 1
coolant cover gasket - 87 only, don't need 928.160.167.01 2
coolant crossover end gaskets 928.106.227.00 1
oil pump pickup sealing ring 928.107.136.04 2
oilpan drainback tube cover seal- don't need 928.107.169.01 1
oil filler neck bottom gasket 928.107.307.00 1
air cleaner housing to MAF hose 928.110.132.00 1
intake runners to block gasket 928.110.580.02 2
throttle body to intake gasket 928.110.637.04 2
rubber thrust rings under intake bolts 928.110.694.01 10
right side intake manifold side cover gasket 928.110.713.01 1
left side intake manifold side cover gasket 928.110.714.01 1
rear alternator foam seal 928.603.135.03 1
traingular oil level sensor selaing gasket 928.606.213.03 1
exhaust manifold sealing rings 944.111.205.00 8
front crank seal 999.113.263.40 1
rear main engine seal 999.113.264.40 1
oil pump shaft seal 999.113.275.40 1
front camshaft seal 999.113.282.40 2
base of coolant crossover o-ring 999.701.627.40 1
thermostat housing o-ring 999.701.632.40 1
oil pump sealing ring 999.701.633.40 1
oil filler cap gasket 999.701.846.40 1
rear cam sealing ring, for screw plug on back of head N 043 811 1 2
SET INCLUDES
? 900.123.115.30
GTS QUANTITY:
SET INCLUDES
? 900.123.115.30 1
valve stem seals
You guys do realize that you are talking about two completely different kinds of cam seals, right?
Some of you appear to be talking about sealing the external cam bore holes in the front and back of the cylinder heads, and some appear to be talking about the pins that plug the unused oil holes in the cam bearing saddles...
SET INCLUDES
? 900.123.115.30
GTS QUANTITY:
SET INCLUDES
? 900.123.115.30 1
valve stem seals
SET INCLUDES
? 900.123.115.30
GTS QUANTITY:
SET INCLUDES
? 900.123.115.30 1
valve stem seals
Basic Sponsor
Hi Rob,
As always great info.
Was the list compiled from PET or an actual seal kit?
I have found differences between the Porsche kit and the VR supplied kits.
Best,
Roger
Best,
Roger
Archive Gatekeeper
Hi Roger-
The GTS kit contents are based on reality, the '87-91 are straight outta the PET pdf. I put them together when I was surprised to find that the GTS seal kit does not include the valve stem seals. I'm pretty sure the GTS kit is accurate, I'll let you know what's 'extra' in the box when we're done building the engine
Captain Obvious
Super User
Super User
I got these pins from a good friend. I put them in, but the are not super tight. And when the cam cap goes on, there is about 1/32 of up and down movement - are they supposed to be tighter?
What did you do? Did you put some sealant on the small side to seal it up?
Any chance the ones you have were modified for early '87 heads? I recall early 87 heads have narrower journals, and the pins have to have their diameter reduced to fit.
Just measured a spare one - the pin diameter is 3.41mm on un-modified ones (guessing the .01 is cheap caliper error). They were a pretty close fit on my late '87. The length is 5cm almost exactly - from what I remember when I did this last, there was about 1mm movement up/down in the hole with the cam caps fitted (maybe less - didn't measure, just used fingers to feel how much movement there was)
These are 89 heads and the diameter seems to be fine. Not "hammer it in" tight, but not wobbly loose. I was more concerned over the apparent up and down with the cam caps on. I suppose the idea is that the oil not come shooting out of the hole, but its okay to dribble out?
