Timing Belt / Tensioner Recommendation
#241
Basic Sponsor
PK32v'r is $149.95 and in stock.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
#242
Inventor
Eyeballing is very inaccurate, and you don't know if the original marks were in time.
#243
Harvey
#244
I doubled checked the marks just to make sure. I also did my best to align the new gears to match the old ones. Put it all together and all seems well. Very pleased to hear the engine purring again! Test drive tomorrow but all looks good. There was a bolt that was missing. It goes through the center TB cover to the water pump. Would anyone know that size of that bolt? One last thing; the 20" belt is the answer for the air pump removal (fan belt alternative). Thanks all!!!
#245
Chronic Tool Dropper
Find a local who has a 32vr and use it to get the cam timing correct. Putting the new gear on using the calibrated eyeball index method will get you close. Using the tool will get it correct. Roger sells the tool if you can't borrow one locally. Difference between 'eyeball close' and correct can be several degrees, and that can be a bunch of power left on the table.
#246
Team Owner
The lower front cover bolt is a 6 x 73 usually ACE hardware has these, put some sealant on the bolt when you install it
bolt PN 900 074 263 02
#248
500 miles and all is good. I did notice that my PS pump is making noise when cold. I put new fluid in after the TB job. I did notice the fluid appeared to have bubbles or foam in the reservoir during the time when the pump was making the noise. Maybe the pump is going out?
#251
Team Owner
you should get a bolt into the timing cover, as it will begin to leak coolant at some point add some PTFE pipe sealant to the threads
#253
Team Owner
put a washer onto the bolt.
the spacer in the timing cover can fall out as its a separate piece
#255
