928 Forum 1978-1995
Sponsored by: 928 Specialists
Timing Belt / Tensioner Recommendation
Old 01-06-2010, 11:42 AM
  #181
vbatla
vbatla's Avatar
Are these water pumps any good?
http://cgi.ebay.com/ebaymotors/New-P...#ht_1128wt_923
Old 01-06-2010, 12:01 PM
  #182
SeanR
SeanR's Avatar
Originally Posted by vbatla
That is the one thing (of many) you don't want to go cheap on. I'd not use those.
Old 01-06-2010, 12:05 PM
  #183
vbatla
vbatla's Avatar
Flywheel Lock came in today. Time to get to work....
Old 01-06-2010, 12:08 PM
  #184
ROG100
Basic Sponsor
ROG100's Avatar
Those are Hamburg Technic water pumps and a no no. The quality was not good.
Old 01-06-2010, 12:09 PM
  #185
ROG100
Basic Sponsor
ROG100's Avatar
I have a ton of air pumps around the workshop that we have taken off cars.
Also a brand new one in the box.
Roger
Old 01-06-2010, 12:14 PM
  #186
vbatla
vbatla's Avatar
Figured as much. Going to dive in and see what all it's going to take to bring this thing back to life...
Old 01-06-2010, 12:22 PM
  #187
SteveG
SteveG's Avatar
Vbat: I don't want to imply anything by this suggestion, but do you have [edit to correct] John Kelly's book or I would suggest Dwayne's write up (based solely on his other work - I have not read the TB thread) to aid in this job? It will answer many questions; this thread is already 13 pages and hit some OT areas w/o discussing the job itself; it is a minefield for a newby. A photographic memory helps: Bag and mark wp bolts, they are not all the same length, one or two need RTV, getting the balancer off and the thrust washer replaced correctly, just to name a couple; RL is here to help, but it's just easier.
Old 01-06-2010, 12:25 PM
  #188
Imo000
Captain Obvious
Super User
Imo000's Avatar
Originally Posted by dprantl
My car passes smog just fine with no air pump and stock cats.
Dan
'91 928GT S/C 475hp/460lb.ft
My brother's '89 did too. HC was a bit on the high side but it passed.
Old 01-06-2010, 12:29 PM
  #189
Imo000
Captain Obvious
Super User
Imo000's Avatar
Originally Posted by danglerb
Huh, I thought the early cats would go bad without air injection, maybe the o2 sensor just runs your motor a little lean or something to compensate? Maybe its just the older generation cats.
Maybe commenting on soemthign that you have no first hand experience is not a good idea either.
Old 01-06-2010, 01:25 PM
  #190
PorKen
Inventor
PorKen's Avatar
They stopped looking under the hood here more than a few years ago, no longer do roller testing, and we don't have clean rooms. I've passed smog with L-Jet and LH-Jet, in a good state of tune, with newer O2 sensors and stock cats, but without the airpump (atmo gas vapor and crank vent too, stock and my chips) with no problem. HC goes from zero to more than zero, but well below the standard, and they all have passed on the first pass.
On the 928, air is injected in the rear third of the cat(s) to reduce HC (the front part is for NOx, I had this assbackwards for many years). Without air the cat will run cooler. At WOT, stock AFRs go into the 12's and the bypass valve under the airbox diverts air from the cats to the airbox so the cat(s) don't overheat.
AFAIK, you need serious engine problems to plug up a cat.
Old 01-06-2010, 01:42 PM
  #191
vbatla
vbatla's Avatar
That's interesting. If the CAT runs cooler without the air pump then that's the way for me to go. I was concerned that the CAT would run hotter, resulting in heat coming up through the console. Not good for a Texas car...
Old 01-06-2010, 01:57 PM
  #192
danglerb
danglerb's Avatar
You mean like you commenting on me?
My point of reference are the troubles people have gotten into on the Mustang groups taking off air pumps, or more commonly going to a shorter belt and skipping them. In Calif thats tampering, and removes any limit to the cost the owner has to bear in getting a car to pass the smog inspection.
I also have a bit of a bias against the if it makes more smog it must make more hp school of thought, many control systems don't work well with parts of them tinkered with.
Old 01-06-2010, 02:13 PM
  #193
PorKen
Inventor
PorKen's Avatar
It still going to be hot. Fix your motor mounts, or put a (12 x 3 x 3/4") piece of sheet rubber between the oil pan and the crossmember to help seal the console.
If you want to run cool, a X-pipe is what you want. Coolant temps will drop too.
Old 01-06-2010, 02:21 PM
  #194
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,631 Likes on 1,482 Posts
replace the water pump bolts go to ACE hardware they sell the correct lengths
If you swap out the oil pump gear the updated version is steel the new gear is installed without the 1mm spacer thats behind the aluminum gear.
Also consider replacing the oil pump O ring and radial seal as well as the 3 O ring seals under each bolt
Old 01-06-2010, 02:49 PM
  #195
Stromius
Stromius's Avatar
Great advise I also got. I soaked them in Kroil/PB Blaster, tapped them with small hammers etc etc. Here's what they look like (eek). Note some didn't any of the PB/Kroil despite a day of liberal application.
Quick Reply: Timing Belt / Tensioner Recommendation
