The S4 brake conversion thread (tech with pics)
In an effort to dispell all the mystery and false information on this issue I'm documenting the whole process in steps with pics. This is on a stock 1981 US non-s car. I simply mocked up the setup this evening and here is what I found.
1: Whoever suggested to change or check the front wheel bearings was correct and I appologize. You cannot remove the dust shield withough removing the hub and bearings. The 993 (NON TT) crossdrilled rotors also did indeed run into the dust shield so I removed it.
2: The stock bolts that hold the stock caliper and are used to mount the adapters are too long and I will be obtaining the correct size tomorrow.
3: The 993 rotors are NOT hubcentric to the hub, they are actually a little larger but once the two beveled set screws are locked in place it centers itself and I don't see this being an issue with a little locktight and the lugs torqued to spec. Everything should hold in place snug under normal driving conditions.
4: I ordered stainless brakelines for an OB and not and S4 so that won't work since the connection at the S4 caliper is a block style fitting instead of a threaded style. Those will get sent back.
Here are some pics I will go step by step tomorrow. The good news is the adapters, rotors, and calipers fit perfect all bolted up. I will need to figure out what to do with the dust shield.
![](http://i68.photobucket.com/albums/i32/chewy8000/437a244a.jpg)
![](http://i68.photobucket.com/albums/i32/chewy8000/07c37573.jpg)
![](http://i68.photobucket.com/albums/i32/chewy8000/3efed128.jpg)
looks great . those rotors look larger diameter than S4, are they? near 13" rotors have 4 and 5 hole rows, and the S4 rotors have 3 and 4 hole rows like the picture shows, BUT, the pad runs real close to the hub and this one looks like it has more room.
mk
mk
Chewy,
Sorry I was late with these, it might have helped had i got them to you BEFORE you did the upgrade. (Maybe it will help someone else doing this)
Dug up some pics from the 2004 OCIC where we did the upgrade as well. You had the 81, so it was a little different. I retained my stock spindles and just went with:
Painted Calipers off an 89 S4
Adapters from DR
New brake lines
New rotors and bearing
All new mounting bolts
New S4 Dust Shields
I pretty much just posted the whole folder I found, so sorry for being so pic intense. Hopefully someone can get some details out of the pics themselves for future upgrade.
Adapters from DR
New brake lines
New S4 Dust Shields
Mark the rotors I used are actually 993 rotors not S4. I can measure them when I get to the shop. Thanks for the pics Chuck! Looks like I need to order some S4 dust shields.
Rest in Peace
Man of many SIGs
The problem is not with the radial bolts that go through the caliper, the problem is with the lateral bolts that hold the adapter to the spindle. With OB brakes the lateral bolts go through a clearance hole in the spindle and a clearance hole in the caliper, then thread into nuts welded to the backing plate. So, they are too long. They run into the S4 backing plate. You could drill the backing plate or cut the bolts to length, but really it's best to just get the right length bolts.
I got the right S4 stainless brake lines in today and finished up the fronts.
![](http://i68.photobucket.com/albums/i32/chewy8000/9649820d.jpg)
Here are the correct bolts I found at Auto zone.
They actually come with nuts that you can install on the back of the adapter for further security.
![](http://i68.photobucket.com/albums/i32/chewy8000/db146259.jpg)
The adapters didn't quite fit exact and I had to grind a little of the top mount to clear the adapter.
![](http://i68.photobucket.com/albums/i32/chewy8000/069cc83e.jpg)
Here are the adapters bolted in with the hardware from autozone.
You can see you can easily fit the nut the bolts come with if you would like some extra peice of mind.
![](http://i68.photobucket.com/albums/i32/chewy8000/785e7c2a.jpg)
Rear will be tackled ove the next few days. I haven' painted the caliper like I intended until I make sure they are functional with no leaks. Once they past the test they will get some gloss black treatment.
I got a chance to wrap up the conversion today and bleed the system. Everything turned out great and I can wait to test the new setup. One concern I did have though was how close the front 993 rotors are to the lower ball joints. They don't actually touch but man are they close!
![](http://i68.photobucket.com/albums/i32/chewy8000/e3e72721.jpg)
Man of many SIGs
That looks like the alum. ball joint. Can you confirm? If so, they need to be changed. I believe the steel ones give a little more clearance.
