928 Forum 1978-1995
Sponsored by: 928 Specialists
Which "ford" fuel injector?
Old Dec 8, 2009 | 08:47 AM
kaptnknemo's Avatar
kaptnknemo
Bumbling Neophyte
Default Which "ford" fuel injector?
Anybody got a PN/supplier for an early 86? All of mine are off and it may be easier/cheaper to get new ones than get the old ones serviced. Some peopel have posted that injectors are a "wear" item anyway and should be replaced. Mine have 150K miles on them.
TIA KK
P.S. No mods except for X-pipe, no cats, no airpump.
Old Dec 8, 2009 | 09:02 AM
stolarzj's Avatar
stolarzj
Here is a post I made on those earlier.. https://rennlist.com/forums/928-foru...injectors.html
Old Dec 8, 2009 | 09:29 AM
SeanR's Avatar
SeanR
Call Roger, I think he's got them in stock. I know he's been selling a lot of them.
Old Dec 8, 2009 | 01:30 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
Any late 80’s early 90’s, 24lb Ford, Bosch style injectors will do. You can even use the same O rings that they come with. Lincoln Mark VIIIs have 24lb unit and are called the “blue top” because of the colour of the top part of the injector. I’ve posted this info in a tread that had pretty much everything you needed to know about replacement injectors for the 928.
Old Dec 8, 2009 | 03:23 PM
kaptnknemo's Avatar
kaptnknemo
Bumbling Neophyte
Imo000
Linky please! I did do a search, but got 1 billion replies. Even at 10 replies per minute, it will take me 1 light year to scan them.
TIA KK
Old Dec 8, 2009 | 03:50 PM
Mako 928's Avatar
Mako 928
I got a set a few years ago from www.blueovalindustries.com for just under $200.00
Direct swap O-ring and all for MY '85 '86
Old Dec 8, 2009 | 03:59 PM
dprantl's Avatar
dprantl
I got my 42lb injectors from there too. They were $209.95 w/ free shipping back then.
Dan
'91 928GT S/C 475hp/460lb.ft
Old Dec 8, 2009 | 04:02 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
https://rennlist.com/forums/928-foru...the-928-a.html
The more detailed thread was on the 19lb unit (I thought it was for the 24lb, but besides that, it's still good info) https://rennlist.com/forums/928-foru...injectors.html
Old Dec 8, 2009 | 04:19 PM
linderpat's Avatar
linderpat
sadly, the search function really sucks on here now. I too have problems getting relevant results from searches anymore. It used to be excellent, and all of the collective knowledge on things like injectors were easily found. Not so anymore. Lots of knowledge being wasted and lost.
Old Dec 8, 2009 | 05:22 PM
JHowell37's Avatar
JHowell37
The current ford injector that will work is M-9593-AA302. This is the newer EV6 design, and although it looks different the two dimensions that are important are the overall length, and the diameter of the ends. They are the same. There's no cutout for the metal retaining clips that secure the injector to the fuel rail, but they're not terribly effective anyway, and since the fuel rail bolts to the intake, it's not like the injectors can come out. They have the proper connector, impedance, and flow rate.
Summit Racing currently doesn't have a listing, and I didn't find them on the Ford Racing website, but it is listed in their paper 2009 catalog. A Ford Racing dealer is the cheapest option. The last time I did see a listing which was just a few months ago, the 24lb/hour injector set was $200.
Old Dec 8, 2009 | 05:27 PM
RyanPerrella's Avatar
RyanPerrella
I have a set of the Design II (4 pintle) injectors with the larger o-rings I would love to trade for those that will work for an 85-86
The injectors i have are for an S4 19 lb/hr and I need the correct 25 lb/hr injectors for the 85.
Old Dec 8, 2009 | 05:42 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
J Howell, FWIW there have been a few engine fires due to using the different fuel injectors without the upper guide securing collars, what happens is that the injector gets pushed out of the rail and into the intake just far enough to cause a fuel leak and the rest is a cookout.
IIRC Bill Ball made a post about this fact a few years ago.
I also remember another owner cutting slots into tops of the injectors so the collars could be fitted.
I would say that fitting the injectors without the collars isnt a good idea
Old Dec 8, 2009 | 05:45 PM
stolarzj's Avatar
stolarzj
In the link in my post above, I reference those newer Ford injectors and where to get them cheap ($152). I cut a ring into the plastic body to fit the retaining clip. They fit without issue and are really tight and not moving.
Old Dec 8, 2009 | 05:59 PM
jacal128's Avatar
jacal128
Have you tried cruzinperformance.com, I have talked to Rick and am going to send the 10 injectors ( 2 extra for backup ) I have to have rebuilt and cleaned. Sounds like a good deal to me. $17.00 each plus shipping.
Old Dec 8, 2009 | 06:32 PM
stolarzj's Avatar
stolarzj
Cleaning works well and they rarely go bad. But the newer ones as discussed are a 3rd generation design that has a better spray pattern that has better atomization. I don't think anyone has dynoed back to back to see any difference though. But when you look at $136 for cleaning 8, or 8 new for $152, I'd be leaning towards new. But it's all personal preference.
