928 Forum 1978-1995
Sponsored by: 928 Specialists
Which "ford" fuel injector?
Old 12-08-2009, 06:55 PM
jacal128
jacal128's Avatar
Thats true, I just don't feel comfortable cutting a grove or modifying highly combustible products ( for me that is ) and the new oem injectors that fit are expensive.
Old 12-08-2009, 06:59 PM
Mako 928
Mako 928's Avatar
FWIW the 24lb injectors from www.blueovalindustries.com ( I have no affiliation w/ them) had the cut out for the guide collars. I have had them in MY '85 for a few years now and no problems.
Old 12-08-2009, 07:09 PM
stolarzj
stolarzj's Avatar
Just get them while you can. Those models were discontinued, the replacment is the newer Ford injector that needs a groove added to them.
Old 12-08-2009, 07:14 PM
jacal128
jacal128's Avatar
Are those the $199.99 ones?
Old 12-09-2009, 08:25 AM
kaptnknemo
Bumbling Neophyte
kaptnknemo's Avatar
Got the ford A302 ones on flea-bay 69.00 for 8 used ones, I'm going to ultrasonically clean them and then flow them both forward and back. It's a risk, but I like the "hands dirty" approach to fixing stuff. Getting the o-rings from Roger. RP: I probably keep the old ones until i'm back on the road, but after that I'll give them to you, if you can wait that long!
KK
Old 12-09-2009, 01:25 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
KK
How much will the cleaning costs? Since you have an '86, the O rings are the same as the ones for the Mustang. You can get it any local part store.
Old 12-09-2009, 03:15 PM
Jfrahm
Jfrahm's Avatar
Originally Posted by linderpat
sadly, the search function really sucks on here now. I too have problems getting relevant results from searches anymore. It used to be excellent, and all of the collective knowledge on things like injectors were easily found. Not so anymore. Lots of knowledge being wasted and lost.
It's just the quick search, which returns results based on 'relevance,' that is kinda crappy. The advanced search still works fine and can return threads or posts and sort by date or what have you.
Quick Reply: Which "ford" fuel injector?
