List of Ford & GM OEM injectors for the 928
Captain Obvious
Super User
Super User
I’ve been double checking that the Lincoln Continental Mark VIII injectors that I got before the head gasket blew were in fact 24lb unit and came across this handy chart. These are Ford and some GM OEM injectors and most are plug-and-play units.
Ford 21lb injectors (high) #s: D9B, F65E (305/350 GM)
Ford 22lb injectors (high) #s: FOTE-D9B (vettes and range rovers)
Ford 23lb injectors (high) #s: F7TE, F8TE (7.5L truck)
Ford 24lb injectors (high) #s: F5DE, F1TZ, F2LE, F2LE-9F593-B2A, FMS-M-9593-A302
Ford 24lb injectors Ford 93-95 Mustang Cobra
Ford 24lb injectors 93-01 Lincoln Mark 8
Ford 24lb injectors 95-up Lincoln Continental DOHC 4.6
Ford 24lb injectors 88-97 EFI 460's F250-450 & E250-450
Ford 24lb injectors F350 with V10
Ford 24lb injectors Lincoln Aviator 4.6 DOHC
Ford 24lb injectors Lincoln Navigator 5.4 DOHC
26lb '00 LS1 F body, maybe '99 to?, same as Ford 24's
Ford 30lb injectors (high) #s: E9SE, F1SE, F1SE-E1A (3.8SC and SuperCoupes)
Ford 30lb injectors: 95/96 Ford 4.0L Explorer & Ranger & Other
Ford 30lb injectors: 89-93 SuperCoupe
Ford 36lb injectors: 94-95 SuperCoupe
Ford 39lb 03-04 Cobra
Ford 42lb 99+ Lightning
