STROKER?? Has Ricer Lost His %*&$&#)&^ Mind?
#46
Captain Obvious
Super User
Super User
Or if you are handy, for $1000, build an SC setup like mine (easily doable in 2 weeks) and have about 400-425hp too.
#47
Captain Obvious
Super User
Super User
Larry's sig line shows he has an FZR it seems to gauge acceleration.
And, an XKE in a million pieces.
His mind is calibrated in uncharted territory.
Plus, he's running those old authority chips, not the new Porken set-up.
Regarding conversions, its funny that a 928 engine can fit in a Z car, but not a 944.
However,before the SC, I had a go against a couple 600cc sport bikes (late model ZX6 and CBR 600), above 100mph, they couldn't pass me. These cars, evne near stock form are not slow, especially on the highway.
#48
The power figures don't add up. HP = (torque X RPM)/5252.
Let's use the figure of 330 HP and 421 LB-Ft of Tq at 2500 RPM.
(421 lb-ft X 2500)/5252 = 200.4 HP. That's a far cry from 330 HP at 2500 RPM. To get to 330 HP at 2500 RPM you would need around 694 lb/ft ot tq at 2500 RPM.
I owned a car with this much low end power but it came via twin-turbos and a V12 engine. I would be very leary of someone who gave you these power figures and said there was a dyno chart to prove their claims.
Still doesn't kill my plan, but I will proceed with a tad bit more caution.
#49
#50
If I wanted to simply have cheap hp, I'd have bought a GTO and souped it up.
Or maybe a WRX.
I wanted to do it a little different than most folks. No chevy motor for me, thanks.
Or maybe a WRX.
#51
hmmmm my friend has an old cady 500 collecting dust in his garage anyone have an early 80s parts car they would like to part with cheap ? thumbs up to you project man in the end money talks and its your project the only one it has to please is you.
#52
I've got an Olds 455 in mine. I'll admit to taking a tape measure to it the last time I needed a rebuild. It'd fit.
Something to consider is that these good ol' American iron beasts produce huge torque numbers and will break the 928s dainty transmissions.
#54
Not the sharpest tool in the shed
This phenomena is deja vu. In the late 70's a few people started replacing the 6 and 12 cyl Jag XJ's with 350 CI Chevy engines and trans. I loved the looks of those cars but the gremlins, maintenance cost and parts could empty Bill Gate's wallet. The conversions worked well, passed smog, then, and indeed improved the perfromance and overall enjoyment of a classic un-repeated design.
My take is this. Those Chevy conversions saved a whole lot of cars from the wrecking yard. Much like our 928's they were readily orphaned and only the most committed enthusiasts were able to maintain the original configuration cars. I suspect there were more Jags on the road because of the conversion compared to if the cars were left stock and abandoned.
I like the notion of a full turnkey GM drivetrain and electrical conversion kit. I suspect someone could do it a few times and figure out how to do it right and affordably. There is no question more Sharks would be saved which I think would increase the values of the cars owned by the purists. So I give this a thumbs up.
I would be very interested to find a turnkey business for our cars. I can assure you I would entertain that option for a good condition car with TBF. Same or better performance, lower cost of ownership and greater range of options. Someone's gotta do it.
Here is a link to Suncoast in Florida. They have been doing Jag conversions for more than 20 years.
http://www.suncoastconversions.com/
#55
When used with larger needle and seats and lower fuel pressure they prevent over filling of the float bowls in the corners. This makes for better throttle response off the corners.
It's simply an improvement that gives decent results. It's very popular with offshore carb set ups as well since it helps fight the effects of slosh.
#56
Chevy did something like this before with the ZZ4 I think engine.
That said I think you still might be much better off using an earlier donor car and related parts.
#57
Very good and interesting points. In fact, the bike deal is why the car feels slow. The E-type is now only in a few thousand pieces as it is going together. A 928 is pretty smooth and, at least our '86, needs a few rpm before it wakes up.
Now some thinking on 928 performance in general, namely what can be "wrong" with a 5.0 liter which runs 'normally'. The cams could be off, it could have weak cylinders (various reasons) or a clogged exhaust. Almost all other problems aren't likely or even possible if the car runs normally 'by the seat-of-the-pants'. Solid state engine control is pretty much go-no-go. I get 22 mpg or so on the highway, it doesn't miss and it will rev to proper levels. Two hundred ninety horse or so just isn't very much in a 3 600, lb car. Our 951 is chipped (effective with turbos) and might be 250 hp with 2 800, lb. It is quicker - maybe 11.2 lbs/hp vs. somewhere in the 12's. I like our 928 and I'm not into bench racing arguements, I just don't like having hundreds of useless parts spinning around not doing anything except looking cool. Old Chevies had tin valve covers that leaked with their 4 little bolts, but the oiling system worked.
#58
You could learn a lot about your cars with a trip to a chassis dyno. It's pretty cheap for discovering if the cars are really running to their potential and the A/F readings can be enormously instructive.
I'll wager that cleaned injectors, new spark plugs, a new O2 sensor and new air and fuel filters would make a marked improvement in your 928s performance. And check the vacuum lines, plug wires, etc. It will be an exciting ride if it's running well.
#59
Administrator - "Tyson"
I was just at the SEMA show in Vegas GM announced a new SMOG LEGAL E-rod 6.2 engine check it out...." The engine kit comes with a wiring harness, control module, catalytic converters, exhaust manifold, oxygen sensors, fuel tank evaporative emmisions canisters, air filter, mass airflow sensor, and drive by wire accelerator pedal. The LS3 engine is a 6.2L 430 horse/424 lb-ft package, .... The LS3 kit will retail for around $9,000, but is expected to sell for about $7,900 at your local GM dealership. "
Funny how Todd's 30psi engine that is stock except for 951 pistons has less blow-by than most stock 928's running around.
#60
Good advice on the chassis dyno. I did go to a local one and saw Olsen's and Hackker's on the dyno. I think "Murf" was there also but didn't run while I was there. A few clean 1/4 mile times aren't a bad measure either as trap speed can be a rough guide to hp, even if you can't launch. Mixture info would be great. My 928 has under 60 k, I'm the 3rd owner. I did wires, plugs, TB, air filter, fuel filter and a relay or two.
When I worked at the Chevy garage in the 70's we did have some collapsed downpipes - they were double wall, the slush would hit the hot pipe and collapse the inner wall. I wouldn't doubt my cats may be a little "full", but other than that, the car is at least somewhat OK. Maybe if the Green Bay guys go to Appelton (or wherever that was) again, Ill give it a try. I heard at a local speed shop (buying trans coolers for my overworked Merkur autos) that Jean Louis used their dyno, so 928's are getting strapped down all around Wisconsin. What I shouda done was raced Hackker's 2-valve.
