Question for Kibort, Dangler and other aviation guys...
So if a prop driven plane is tied to a flag pole (hypothetically...) will it be able to sustain flight? I guess what I'm asking is if the wind from the prop alone will create enough [lift?] to keep the plane in the air even though it will remain motionless.
This will help me understand the old conveyor topic a while back...
Thanks guys.
Thanks guys.
Archive Gatekeeper
This experiment is done daily at John Wayne in Orange County. Because of the wealth that lives downstream of the runway in Newport Beach, planes throttle up to 100% thrust with the brakes on, so they can take off and attain maximal altitude before they fly over Newport Harbor.
With the brakes on, the plane doesn't fly anywhere. 'Course, it's not on a conveyer belt....
yes, its called a helecopter ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I know what you are asking, and its not really related to the conveyor belt experiement. that was only overcoming wheel bearing frition force.
This question is asking if the wings can impart a negative momentium as to lift the plane. Yes, its possible. it would be analogous to vectored thrust of a Harrier Jump Jet.
no flight!! the wind must travel over the wing to produce lift. The prop is there to propel the airplane forward ( this in turn will cause air to flow over the wing and produce lift).
Cheers
Dan 1990 928GT
Cheers
Dan 1990 928GT
1979 Euro
I got to take a ride in a confederate air force P51 Mustang. In order to be able to take off on the very short airfield we were flying out of and clear some power lines the pilot had to put the tail against a fence at the end of the runway and firewall the throttle holding the brakes hard. The tail lifted and the motor settled a bit then he let off the brakes for maximum acceleration down the short runway and barely clearing the orange ***** on the wires. Wings did not lift while full throttle with brakes on, only the tail.
Actually if you want to be 100% correct the lift comes form the difference in pressure between the bottom and top of the wing. Bernoulli's principle is the driving force behind the magic of flight. The top of an airfoil is curved whilst the bottom is flat. Air traveling over the top of a wing has to travel a longer distance as compared to the bottom of the wing. Air traveling faster has less pressure than air that is traveling slower So actually the (higher pressure) below the wing pushes the wing up toward the lower pressure (above the wing).
Cheers
Dan 1990 928GT
Cheers
Dan 1990 928GT
