928 Forum 1978-1995
Sponsored by: 928 Specialists
Stroker Scraper Kit
Old Oct 29, 2009 | 01:02 PM
  #61
ptuomov's Avatar
ptuomov
Carl, Greg, Kevin -- Thanks to all three of you for discussing these issues out loud here. I feel that I've learned a lot and I suspect that so have many other readers.
Old Oct 29, 2009 | 01:39 PM
  #62
Fabio421's Avatar
Fabio421
Man of many SIGs
+1 I also appreciate that the conversation has remained civil. All of you guys have alot to offer the 928 community. I know that some of your business' overlap and it's nice to see that you guys can keep things technical for the most part.
Old Oct 29, 2009 | 01:48 PM
  #63
mark kibort's Avatar
mark kibort
So, what is the main purpose of the scraper system?
if you are dry sumped, is there no real reason for the system?
If the need is power based, Joe and mark have the same rear wheel hp, yet one is dry sumped and the other is not. It is a very interesting product, and its great that Carl is coming up with such inovated products, but what is the problem and if there is one, who is likely to have it?
Old Oct 29, 2009 | 02:02 PM
  #64
blown 87's Avatar
blown 87
Rest in Peace
I agree.
Old Oct 30, 2009 | 01:15 AM
  #65
ptuomov's Avatar
ptuomov
Ok, now that the pros have spoken (and I've partially recovered from today's GDP release with a bottle of wine, but that's another story), here's some amateur speculation of what one might try in an oil control system.
Three ideas, all copied from other engines:
(1) an integrated spacer-scraper cut from aluminum
(2) curved oil pan fin extensions
(3) windage screen over the sump deep end
I tried to do what Kevin Johnson suggested and think about it from the original designer's perspective. First, understand what strategy he took. How is the design supposed to work. Second, what constraints the original designer faced.
With the risk of being philosophical, one has to ask the question how to improve on the original design. One could try to be just better than the original designer, and solve the problem better within the constraints than he did. Absent a major technological breakthru, that's not likely. Alternatively, one could relax some of the constraints that the original designer faced and then alter his strategy slightly.
So here's what I am thinking about. First, cut a 3/8 inch spacer for the pan than integrates a crank scraper. The crank scraper would be on the passenger side. This would be too expensive for a car company's accountants, but might be just fine for someone like me who's paying $250 for the spacer anyway.
The original designer IMO faced the budget constraint, mainly having to produce a pan that is easy to cast. Without the casting constraint, the fins on the bottom of the oil pan could take much more interesting shapes. One such shape is this:
Bolt (or weld, depending on a lot of things) these curved scrapers to the sides of the existing oil pan fins. Now, we have these scrapers that are at 45 degree or so angle relative to the crank centerline, so the windage gets under the curved part just right. The 45-degree angle deflects the oil and air towards the deep end of the sump.
In addition, the curve helps in the following way. I believe (but do not know) that the screen that Kevin, Greg, and Louis all use in their systems mainly functions as a device that prevents the oil from being reflected or bounced of from the oil pan bottom back to the crank. That's a big problem and needs a solution. I think that the curved part would use the velocity of the separating oil to screen the oil under the curve and stop the reflection of oil from the pan bottom. The advantage over a screen would be that the "tornado pump" that moves oil towards the deep part of the sump would still work.
Finally, there's a place for the unidirectional screen. These screens seem to help in all the systems that I've seen in two ways. Mostly this is learned from reading Kevin's posts on the internet. First, because they reduce the velocity, they stop reflection or bounce back. Second, because they reduce the velocity, when oil droplets hit oil surface, they trap less air in.
How about placing a unidirectional screen on top of the deep part of the sump? That is, make piece #17 of the old school 928 engine from that unidirectional screen stuff:
What these three measures do not address is oil draining from the heads.
My thinking has benefited from a lot hints that Jim Morton gave me over the phone a couple of months ago. Just recently, I've started to really understand that conversation. Errors and misunderstandings are all me, of course!
Critique welcome!
Old Oct 30, 2009 | 01:27 AM
  #66
928SS's Avatar
928SS
Road Warrior
this all makes my head hurt.
why not just dry sump the beast and be done with it?
Old Oct 30, 2009 | 01:48 AM
  #67
atb's Avatar
atb
Tuomo,
Just a couple of observations:
I think having the scrapers on the spacer is going to put them too low on the crank to be effective, unless they are actually tilted up toward the centerline of the crank. All the scrapers I've seen to date for the 928 sit up in girdle, higher than the pan rail.
Windage screen won't keep oil in the sump if the sump is full and the car is subject to lateral G's, it's not that strong of a barrier.
Old Oct 30, 2009 | 02:29 AM
  #68
mark kibort
just run it stock and be done with it.
Old Oct 30, 2009 | 02:36 AM
  #69
Lizard928's Avatar
Lizard928
What about milling 1/8" off the girdle and making a spacer to sit in there right at the centerline of the crank to scrap the crank. This would be much more effective than down low
Old Oct 30, 2009 | 03:13 AM
  #70
atb's Avatar
atb
Messing with main bearing tolerances is a messy business.
Old Oct 30, 2009 | 08:53 AM
  #71
Kevin Johnson's Avatar
Kevin Johnson
Attachment 395815
Aside: John Beardmore does fantastic work. I really admire him. The subsequent mods he does to the Fiat dry sump (based on the Ford Kent Cosworth edition) are brilliant. Triumph also used screening like this in the Mark 1 2000 straight six until accounting nabbed them.
Adam is correct about the plane defined by the oil pan rail of the block. It is borderline to be effective as a primary scraper. Particularly so if you are using a later variant of the Porsche crank where the swept diameter of the counterweights is "above" that plane, i.e. interior to the block.
Adam is also correct about messing with the bedplate (but more on that in a bit) unless you are willing to regularly advise an align hone or check. Note the elaborate factory fastener torque sequence.
The plane on the bedplate defined by the fastener pads for the 10mm studs is an existing platform that will support the Beardmore style of scraper but which will still allow intersection with the full swept path of the rotating assembly. Louie and Greg both have used it. [Edit: I think Louie actually used the plane slightly above that one with the 8mm fasteners]
The spacer is a great idea -- 3/8" (9.925mm) is about what Porsche dropped the 944 pan (8mm). Just remember that this will affect other components (starter, for example -- I am sure there are others). To minimize the impact, while you are having the spacer made, have receiver grooves cut for a polymer cord insert -- look at a Ford Zetec E alloy sump casting (Focus model). [Edit: Make that the Raceline sump for the Zetec. Or look at the later alloy sump for a Ford 2.3 OHC or the alloy sump for a GM 4.3 V6.]
Attachment 395816
I agree. Use a parabolic cross section for both the vertical and horizontal elements of the curved surface.
Attachment 395817
I think I made Glen (?) an experimental one a few years back. Adam is correct that the screening will not prevent migration of the oil rearwards. I think the original sump well component design by Porsche was brilliant. Accounting nailed them to utilize similar components from the 944 pickup head, I think.
Back to the bedplate. Make small panels for the bay rails on either side. Drill and tap the rails horizontally. Use bottoming studs to minimize the creation of focused stress points by the fasteners. Design the panels so that oil is directed downwards to the floor of the pan or get fancy and create drain tunnels to the sump well like Nissan did with the SR20. I did not want to do this previously because of the desire for a bolt on product. It was a sea change when I finally got fed up and required people to drill and tap the sump well bosses (where your part #17 attaches) if they were not already done.
Critique welcome!
Last edited by Kevin Johnson; Oct 30, 2009 at 09:52 AM. Reason: not enough coffee: Elixir des Lebens
Old Oct 30, 2009 | 09:06 AM
  #72
Kevin Johnson
One of the maintenance issues with the Panzerkampfwagens was that the factory engineers were continually trying to improve the designs because the [lives] of the occupants depended on it.
I cannot imagine anyone who might be related to the philosophy behind the current discussion and tanks in WWII. Hmmm. Maybe I can at that. France was pretty pissed off about that.
Old Oct 30, 2009 | 12:11 PM
  #73
mark kibort
I guess I just dont understand what is trying to be improved. I think the panzer factory engineers were trying to improve safety by improving things that could be improved to make them safter or and more dependable. Does the scraper improve anything? save HP by reducing whipping loses? keep more oil in the pan for less chance of oil starvation? what about the fact that all that oil whipping around could assist with piston bottom and pin lubrication?
All the work is extremely interesting and from a flow perspective, i understand what can happen with such a contraption. BUT, what is the goal here?
Hasnt there been some engine failures with these types of devices installed?
I have a hard time thinking about using something like this, after 105 race days with a bone stock engine running the snot out of it and no issues, or hints of dependabilty issues.
Old Oct 30, 2009 | 12:35 PM
  #74
Kevin Johnson
I agree that is what Dr. Porsche was after.
Yes, it does. This is probably why Porsche used and continues to use the technology.
Yes.
I mentioned briefly in another thread that the use of crank scrapers in a dry sump pan increased the output of the engine by 5% at 6500 rpms.
Yes. There has been a lot of attention paid to the vector that can be imparted to oil in the pan towards the sump. Less attention has been paid to the slow return from the heads of foamed oil. Look at Louie's video. For the umpteenth time. This tripped up Porsche in the M96/M97 as well.
Mark, I suggest you review the Rennlist threads going back at least five years about why Porsche withdrew dedicated oil squirters. If Porsche had looked at BMW or Honda they could have added slots to the beams. This merely increases the probability of oil landing under the pistons. It does not result in a net increase of oil to the windage cloud since the oil has already passed through the bearing.
Porsche had the same opinion in the final year where they hand selected engines to provide back door factory support. Those engines failed near the end of the season. I know you feel you push the car to its maxima. It could just be that there are other drivers that push it harder both at present and in the past.
Something to think about...
Old Oct 30, 2009 | 12:57 PM
  #75
mark kibort
you can see my videos. all shifts are at or near redline, you cant push the engine any harder than I am. WOT is WOT and redline is redline, and duration between drivers will be minimum. The times I run are top WC touring times at a track near you. After running 7 full racing seasons, and no issues, along with that engine taken apart and oil analysed to see what was happening, that could be a clue that things are good with wear patterns under extreme use.
you tell me of how this engine could be pushed harder at one of the most demanding tracks in the world.
http://www.youtube.com/watch?v=ddvWNNBDEp4
Anyway, if you are not racing the 928, its probably not an issue. 5% HP saved is very optimistic and not proven. for example, dry sumped vs non drysumped has not yeilded any HP gains in the countless dyno runs between Mark A and Joe F and their identical engines. in fact the stock set up from Joe , has generally made more HP. Plus, that number is very dependent on several factors. rate of change of acceleration , being the most dominant. are we talking quick revs , like blips for shifs, 1st gear or 5th gear??? These are HUGE factors for HP savings. Just saying 5%, is plain silly.
I would be more concerned with the return of the oil to the pan, as Greg B has mentioned. Factory designs vs us using napkin drawings of how it should be designed, is a little risky, in my opinion.
mk
I
