928 Forum 1978-1995
Sponsored by: 928 Specialists
What to do with bad block?
Old 10-26-2009, 12:32 AM
brian928
brian928's Avatar
Default What to do with bad block?
I'm starting to get an '86 5-sp up and running. It suffered a broken timing belt and bent at least 6 valves. It then spent 8 months at some regular car shop where they took the heads off and who knows what else they butchered.
I bought the car and found an engine with a bad block. The owner had run the car up on a curb ripping the A/C compressor off. It broke both parts of the block and took off half of the pan. My plan is to take the heads off of this
engine and install them on the '86.
Is there any value to the the crank, rods, and pistons in the bad-block
engine? Anybody want or need them?
What should I do with the block? Will an aluminum recycler take it? I've seen tables made with the block. Are there plans or parts to make a table?
TIA,
Brian
'86 928 5-sp projectcar
'83 928S racecar
'87 938S4 streetcar
Old 10-26-2009, 01:11 AM
cold_beer839
cold_beer839's Avatar
I'll buy the cams if you still have them and they are in useable condition.
Old 10-26-2009, 01:13 AM
bronto
bronto's Avatar
I thought the BBQ was a great conversion.
Old 10-26-2009, 02:29 AM
RicerSchnitzzle
RicerSchnitzzle's Avatar
Recycle the block? Has to equal a ton of aluminium cans.
If it hit hard enough to break off the pan and the motor mounts, I would not trust the crank and rods. You might get a couple bucks on ebay, but it's hit and miss.
Coffee Table, BBQ.
Parachute for drag racing, just toss it out the hatch after 1/4 mile.
Old 10-26-2009, 03:23 AM
6mil928
6mil928's Avatar
Location: No where Oklahoma AKA "The Dust Bowl" In The Arm pit Of Hell
I'd like to make a coffee table out of it.
Old 10-26-2009, 03:55 AM
mark kibort
mark kibort's Avatar
85 PISTONS are worth something. thats the basic ingredient for the 5 liter 2valve. However, you need to find someone taking a 4.7 and boring it out too 100mm. OR, someone doing the conversion that cant find an 85 block, and / or only has access to an S4 block and is doing the conversion.
Old 10-26-2009, 06:12 AM
danglerb
danglerb's Avatar
Don't pistons need to fit the block, so swapping pistons between blocks would be hit and miss? and boring out a 4.7L isn't too common is it?
I think you should plan on a complete valve job regardless of which motor you take the heads from.
Other parts off the bad block are desirable, the air filter box is NLA, good timing belt covers and parts are wanted, flywheel, etc. The bare short block if the block is damaged seems about the only part nobody wants.
Old 10-26-2009, 01:17 PM
brian928
brian928's Avatar
Thanks for the info. I'll go ahead and take the pistons/rods/crank out of the block
and see what they fetch and throw the block away.
After this I'll be doing a detailed inventory of the engine parts that came with the car.
Then part with the extra parts such as the cams, extra intake, timing belt covers.
Thanks,
Brian
Old 10-26-2009, 01:44 PM
Mike Frye
Craic Head
Mike Frye's Avatar
I think you might find someone who would be interested in the block if you're just throwing it away. I've got a cooked block that I'm hoping to convert into a coffee table. Jason said he'd like to do the coffee table thing with it. How about putting it up for anyone who can come get it?
Old 10-26-2009, 01:58 PM
GlenL
GlenL's Avatar
70 lbs, abouts.
The problem is the studs. They'll want those out and will lower the price greatly if they're in.
Old 10-26-2009, 02:04 PM
kccampro
kccampro's Avatar
I've scrapped several blocks... pulling the studs is SUCH a PITA... not doing that again. Now I just throw them in the aluminum pile studs and all.
Old 10-26-2009, 02:09 PM
ptuomov
ptuomov's Avatar
I might be able to use the rods and crank for a potentially destructive experiment. Depending on the price, of course. pm me or email me at <my user name>@gmail.com.
Old 10-26-2009, 02:38 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,684 Likes on 1,300 Posts
Agreed, but the block studs are worth saving, as they're NLA from anywhere. You just need to double nut the stud, heat the crap out of the block and turn the stud out. If you're straining on the wrench, the block isn't hot enough.
FWIW, I bought a set of those stud remover sockets and managed to ruin about 3 of the studs by not heating the block enough. I ended up buying a TBF block from Mark A just to harvest the studs via the doublenut/heat recipe.... (I then gave the block to Greg for practice for his WP impelller repair tool)
So - save the studs!
EDIT - at least the girdle studs. Dunno if the head studs are still available. (Which of course begs the question- can one use S4 head bolts with S3 heads/blocks?)
Old 10-26-2009, 04:49 PM
86'928S MeteorGrey
86'928S MeteorGrey's Avatar
When I was researching parts while I was preparing to build my S3 engine, I read somewhere that you can upgrade to the S4 style head bolts from the S3 style studs/nuts. Once I read how much of a bitch it is to remove the studs though, I decided to leave them and get new head nuts. IIRC, the only real benifit changing from the studs to bolts is the ability to remove the heads while the engine is in the car right?
Make a table. At least yours is broken to the point that even if someone comes up with a perfect fix for TBF you won't be tempted to sell your coffee table...
Old 10-26-2009, 05:41 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
If you dont' care about having an A/C, you can just swap out the oil pan.
Quick Reply: What to do with bad block?
