928 Forum 1978-1995
Sponsored by: 928 Specialists
Norcal Lemons update!!!! 187whp 246torque :>)
Old 10-21-2009, 08:22 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Nice progress but don't post anything on cheating as it's an open forum and anyone can read this.
Old 10-21-2009, 08:33 PM
IcemanG17
IcemanG17's Avatar
Good point.....but I wouldn't call it cheating...as we will document it in our "build" sheet documenting expenses.....so if I can get a set for $200 and sell something off the car (say exhaust system) for $200...then I'm golden..& thats the plan!
Old 10-22-2009, 12:41 AM
Fabio421
Man of many SIGs
Fabio421's Avatar
Originally Posted by IcemanG17
I am quite optimistic about our chances if the 84 holds together...given the "team" of drivers.....Mark Anderson....Mark Kibort....myself (weak link) Clint and John (Evil Genius racing) its safe to say we should be contenders......
But we have to finish this one 1st! :
With that set of hotfoot drivers, that poor engine will never make it throught the whole race unless you put a rock under the gas pedal.
Old 10-22-2009, 01:27 AM
IcemanG17
IcemanG17's Avatar
I actually think the opposite...there will be ALOT of traffic slowing everyone down until the bulk of the cars break....and we will be driving conservatively to "save" the car for at least the 1st day.....since many of the "fast" cars don't finish the 1st day....its all about doing "clean" laps...you have to finish to win!!
another dyno update....after removing the cat and installing a single 2.5" system it went to 187whp @ 5250 and 246ftlbs @ 3125....pretty good for a 1984 automatic.....
Old 10-22-2009, 05:08 AM
vwdmc16
vwdmc16's Avatar
i am kinda disapointed at the run after the exhuast, that was alot of work for 1 hp, but it did raise the powerband up. my camera died but ill get a picture of the budget system for you guys, it still has the stock primary muffler, then it goes to a polished magnaflow fart can looking muffler at the end we had laying around, it looks alright and it cost just about nothing in parts, much louder now but it is a bit raspy.
i was making a video of the last run but i ran out of gas! still i think with about 9' of base timing and maybe a little bit of leaning it out. it may hit 190 like i predicted.
Old 10-22-2009, 11:38 AM
BC
BC's Avatar
How does one get the proof of the 500 dollars?
I have an 86 that I got in trade, sold everything off, and now I have the body - is that considered free or negative $ since I sold everything? I have some emails, etc of the sales of the pieces. Then if I can piece together the car from parts I have to racing form, without buying anything - is that the idea? I rebuilt a 4.5L engine that I already had from another car - is that technically free?
Old 10-22-2009, 12:00 PM
123quattro
123quattro's Avatar
They aren't super sticklers about the money if the car looks like a piece of crap. Rust and dents help your cause a lot. The car we run was more like a $1500 car and they don't mind it.
Old 10-22-2009, 12:21 PM
VehiGAZ
VehiGAZ's Avatar
You are pinning your hopes on the wrong number... torque is what will help in this race, which will be tight, slow, and traffic-filled. They'll never need max power output, but they will use the available torque on the exit of every turn...
Old 10-22-2009, 01:54 PM
123quattro
123quattro's Avatar
Having a reliable car and getting no penalties is 10x more important than having a fast car. It's a war of attrition.
Old 10-22-2009, 05:53 PM
IcemanG17
IcemanG17's Avatar
Heres the dyno run....TORQUE is what this motor has plenty of....no RPM on the bottom but I think it starts at about 2500rpm with 236ftlbs.....127hp down there too...not bad really......so I think our ideal powerband will be up to about 5500rpm...nice and conservative to make the motor last....
also the AFR is not correct...it wasn't printed on this chart...but was a steady 13.3 falling to 12.8 up top
Old 10-22-2009, 05:55 PM
dprantl
dprantl's Avatar
Uh oh
Dan
'91 928GT S/C 475hp/460lb.ft
IcemanG17
IcemanG17's Avatar
this is SO true......you don't need a "fast" car until the last two hours of the race....assuming you get there....put your best driver in for the last stint and let her rip!! & we have some excellent drivers on the team....
Old 10-22-2009, 07:25 PM
mark kibort
mark kibort's Avatar
You asked or commented, so Ill make a comment.
No, the torque is only an indication of how flat the HP curve is. its is actually pretty flat for a 185hp engine, but still, its only 185hp. you will operate the car from 4500rpm to 6000rpm or you will be losing valuable acceleration off any turn.remember, if you are not at 4000 to 4500rpm off the turn, you will be in the wrong gear and all the hp that a stroker has, will barely be better! (or torque) . Remember, HP at any vehicle speed will determine the REAR wheel torque. of a turn, etc, you want as much power that is possible.
mk
Old 10-22-2009, 07:30 PM
mark kibort
The nice thing about the hp curve is that it is pretty flat, so short shifting the engine can be done without really doing too much damge to acceleration "off the turns". not a huge difference from 6000rpm shifts to 5500rpm limit shifts.
what is the rpm scale on the bottom of the graph?
Old 10-22-2009, 09:00 PM
PorKen
Inventor
PorKen's Avatar
Are the stock downpipes to the (now removed) cat still on there?
Going to 32V downpipes, grinding out the cast iron manifold outlets to the 32V gasket ID, stock single catback w/carved pumkin, and ~13° ignition advance made the lil' ol' 4.5 in my '81 auto make over 200 rwhp and 270 rwtq sae.
With 16V single cat downpipes into a 3" single w/flowmasters, I couldn't get over 180 rwhp and 220 rwtq.
(FYI: stock exhaust system measurements)
Quick Reply: Norcal Lemons update!!!! 187whp 246torque :>)
