Official "SharkPlotter" thread
Finally geting to use SharkPlotter for first time. Same as Ben (FUSE69), I'm also geting division by zero errors on Windows 7 Lite. Though I think Plotter version is older than 1.0.018 if it makes any difference. Was there ever any solution for this error or do I just find different laptop to run it?
Shark plotter doesn't like using a 'comma' as a decimal place (as we use in Europe), but instead is looking for a 'period'.
All the user configurable data that is in the sharkplotter.ini file needs to have any 'commas' replaced by 'periods'.... (Except data that specifies 'window size')...
Then you should be able to get it to work correctly.
Jim had mentioned that he would look into fixing this, not sure if he has, as I haven't used SP for a while and thus haven't looked to see if there are any program updates...
Win-7 is causing some issues for the updater but the download should install OK.
(The simplest way to get around Win7 issues is to turn off "UAC" (Windows control panel, select small-icon view and click on "User accounts", then "Change User Account Control (UAC) settings", and set notify to "never"). Do the update, make sure everything works, then turn UAC back on if you want).
Cheers, Jim
Thanks for the advice. I don't know where I got idea 1.0.18 was latest version. In any case I tried both 1.0.38 and 1.1.26 on different laptop. It gets even more interesting. No matter what settings I put into INI file before starting plotter.exe it still gives same error and entire INI is deleted. Didn't notice that before. Never seen any software do that.
Thanks, Jim
