FYI: Harbor Freight PASS/FAIL Thread...
Maybe it'll even useful for my visit tomorrow, on behalf of my son-in-law, to buy him a jack with the $40 off coupon in the back of the current R&T (and I think the other buff books.)
Thank you, Mr. Bolster. Have you met Mr. Champagne?
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
http://garagejournal.com/forum/showt...ghlight=harbor
The Harbor Freight PASS/FAIL Thread...
The problem with HF is that some of their stuff is OK, and some of it is horrible. But you never know which is which, till you buy it and try it.
So what if we made a thread where we posted our HF purchases with a PASS or FAIL grade? After awhile we could check this thread and see what's what.
Thread started: 12/27/2008
Delmar O'Donnell Bolster, GoPhD.
A bona fide Soggy Bottom Boy.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxx
IMO, their big roll-around tool cabinets are a screamin' deal. At least as good as Sears.
Last edited by Fogey1; Sep 2, 2009 at 10:52 PM. Reason: to add something else. duuhhh. ;-)
39178-0VGA 450 lb tranny jack: PASS/FAIL- Worked ok but listed to the side with only ~100 lb 5 spd gearbox on it, near the top of its travel.
91781-0VGA 3000 lb winch: PASS - mounted in back of garage to move engineless sharks in/out
37909--0VGA 3 piece set of long reach hose pliers: PASS - Love them...
43753-0VGA - clamshell spring compressor: FAIL - claws too thick to grab a 928 front spring
37892-1VGA - radiator fin comb- PASS - perfect for striaghtening A/C condenser fins post- TB/WP jobs
35556-1VGA seal puller - FAIL- broke 1st time I used it.
Rob, is this the one Dr. Bob & I were going to pitch in on?
Nope, the good one is different- works like a charm, I already tried it. Not from Harbor Freight, though it's 100% all Chinese- surprised they don't stock something like it.
It's here ready to be used, all we need is to have the GTG!
The HF clamshell compressor got tossed in the trash with extreme prejudice.
Including the item number like Rob did is a good idea, and pict or link if you can since HF often has 5 versions of the same type things.
And a 928 is a long way from a '67 bug!
Tie Rod Separators Fail. Shattered one on my W202 Mercedes upper control arm.
Leak Down Tester: Pass. However, complete judgment will be passed when I get the motor in and started.
Harbor Freight is a mixed bag, lots of junk, some ok, some same as everybody else. Batch to batch, even same sku on the shelf quality may vary from junk to fine. Things that look the same may be very different, a 13 pc socket set might be great and the 14 pc junk. Usually cheaper is not as good, and Pittsburgh is usually the good brand.
Customer Service is usually excellent, anything under warranty is quick and easy and "hand tools" are lifetime warranty, so take those sockets etc. back. Many items have short, 30 to 90 day warranties, check them out right away and keep the receipts. Out of warranty, or no receipt and I don't think even a manager could override the cash register.
OTOH managers may pull up old sale prices etc. if you ask on bigger ticket items.
Heavy stuff, cranes, jacks, engine stands, jack stands, usually gets good reviews.
Electric tools need to be checked immediately, but I skip the extended warranty for most since failures are doa or a few hours of use.
Heavy Tranny Jack (850lb?)
1/2" drive Chicago tools electric impact wrench
Knock-off dremel + bits
Bearing / Bushing pusher kit
Engine lift, up to 4000 lb
Fail
Small punches and chisles (not hard enough/deformation)
Mediocre
12 Ton Shop Press (Excellent for car stuff, but unit is not quite square)
This is the only thing I've ever bought from HF - (It's a $2000 plane ride away)
