Engine not running
Engine not running
I'm done in ft lauderdale for a few days at my dads friends shop and i fixed a bunch of problems with my car, AC, half shafts. I go to leave and now my car wont run. It cranks, starts to run and then either barely idles or dies. if you give it gas there is a lot of sputtering but it wont rev at all. Any ideas? i dont have much time im supposed to be levaing today.
Are you sure it's fuel? The PO of my car spent $100's tracking down issues that I later resolved to be a bad Ignition relay.
Edit: If you want to check the 53 relays, get a multimeter and set to continuity (beeps when you touch probes together). Alligator clip them to 87 and 35 on the bottom of the relay. Get a nine volt battery (or a battery jump start box, or a 12V DC Adaptor) and touch positive and negative to 85 and 86 on the bottom. You should hear a click and get a tone on the meter while you apply power. If you don't, pull a relay for something you KNOW works, like the horn, and make sure you're doing it correctly. If you are doing it correctly and you have a bad relay, swap it with something less important and pick up some Audi 53s from Roger at 928s'R'Us.
I don't believe the 79s CIS had fuel rails. Also sorry i didn't mention but i did put a new fuel pump relay in i had. It didnt make a difference though.
Oh sorry, i didn't see ignition relay not fuel relay. I'll have to check when i go back to my car week after next, its stuck down there now for the week. The car would start, just idle very badly and not rev at all, could that still be the ignition relay, I'm not sure what that does ?
Sounds like a fueling issue.
There are many sources for that on CIS cars. But if your car has an intank pump it could be running on that, while the external one could be pooched.
Not sure if the 79s had the secondary pump for some climates though.
May want to check the .4 and .6 ohm resistors. If one has a bad/corroded connection it would start but put out less than 3 volts in the run position and cause similar problems.
Dennis
Dennis
Chronic Tool Dropper
Go back and see what was disturbed in the engine bay during the AC work. Did the car run OK at any time after that work? Generally, I try yo look at damage thet --I-- might have done when a new condition arises immediately following work I did.
Testing fuel pressure in a CIS car generally requires a set of test CIS gauges, since you are testing for several things at once. You'll be looking at control pressures as well as supply pressures. CIS is an amazing system, but has no tolerance for dirt or hamfisted adjusting. Check all the pressures before you tweak anything.
