928 Forum 1978-1995
Sponsored by: 928 Specialists
Broken WP bolt
Old Aug 1, 2009 | 08:59 PM
  #61
Mike B's Avatar
Mike B
Done With Sidepatch
Great job and congrats Malcolm! Time for a well earned cool one!!!
Old Aug 1, 2009 | 09:01 PM
  #62
heinrich's Avatar
heinrich
928 Collector
Thaaaaat's ... disappointing Malcolm .... we were hoping for a replacement engine ... perhaps some JB Weld ... or very worst case, tap to several sizes bigger Imperial and instal a nice fat bolt. Oh well ... can't win 'em all!!
... see? It was - in the end - just an engine. YOU WIN
Old Aug 1, 2009 | 09:07 PM
  #63
the flyin' scotsman's Avatar
the flyin' scotsman
BTW............major points if you know/guess why only this bolt broke at this location...........see previous pic for big clue.
Old Aug 1, 2009 | 09:24 PM
  #64
Lizard928's Avatar
Lizard928
Congrats!!!
Old Aug 1, 2009 | 09:48 PM
  #65
heinrich's Avatar
heinrich
928 Collector
Rust, indicating a leaky seal at that area.
Old Aug 1, 2009 | 10:08 PM
  #66
the flyin' scotsman
Correct H...........the water bridge had a small leak that every once in a while would leak into the block cavitys.............the ones either side of the bridge. It so happens the bolt that broke screws into the block exiting at the RH cavity.
Now once I finish cleaning the old gasket residue I'll install the new WP with new bolts; what do I put on the bolts to prevent future siezures?
Does the WP gasket go on dry?
Old Aug 1, 2009 | 10:32 PM
  #67
928 at last's Avatar
928 at last
Hey Malcolm!
Great work with the bolt.
Did my WP/TB job a few eeks ago, we used Loctite Anti-seize liberally applied, and then the bolts torqued to spec, and although the instructions that came with the pump said to install dry, I couldn't over ride my previous experience, and used a VERY thin coat of the Loctite Blue gasket stuff. Well over 1,500 miles now and no issues.
Best,
Rob.
Old Aug 1, 2009 | 10:35 PM
  #68
928 at last
Make that "W" eeks ago.
And, it's just that after prepping the block surface for the new pump, I have this (Maybe irrational fear) of missing a small score on the aluminium surface that'll allow a seep.
Old Aug 1, 2009 | 10:48 PM
  #69
the flyin' scotsman
Thx Mike...........radio is on in the garage tuned to the Stamps game so I'll crack one or two and enjoy.
anytime you need the engine hoist let me know; I/we can deliver or my previous offer still stands
Old Aug 2, 2009 | 12:45 AM
  #70
the flyin' scotsman
One last point...............I did NOT replace the WP when I replaced the timing belt and installed the Porkensioner 2 years ago......why?............there was no issues with leaks or bearing.
Why did I replace it now...........because I read all the stories of WP failures and the catastrophic effects that as I was doing a whole bunch of PM I'd do the WP also.
Is there anything wrong with the old Porsche WP.............NO.
Much food for thought/discussion in the ongoing 928 WP saga.
Old Aug 2, 2009 | 01:56 AM
  #71
86'928S MeteorGrey's Avatar
86'928S MeteorGrey
I got it directly from Greg Brown to install the WP gasket dry. I'd assume anti-sleeze on the WP bolts... But which type? The copper or the silver graphite?
Old Aug 2, 2009 | 03:54 AM
  #72
Lizard928's Avatar
Lizard928
silver when dissimilar metals.
Old Aug 2, 2009 | 07:33 PM
  #73
worf928's Avatar
worf928
Originally Posted by the flyin' scotsman
Major success...
Great news!
