Broken WP bolt
#46
There's not enough bolt meat remaining to get a good grip on the FBB; tried a few times now and no go.
Wife just went to town to buy a hand held butane torch which heats to 1300C, I'll just melt the thing out.
#48
#50
Dave & Colin..............appreciate the concern but the handheld butane torch is rated for 1300C output and I've no desire to hold it close to the block to get anywhere near that temp.......waving the torch to heat the block is the idea.
Given that I have heat and LH & RH drills and 'Sea Foam' lube tonight my strategy is to soak all night long, drill with a small LHD bit, heat then drill and heat with consectutive bigger RHD bits.
I will use the old WP as a guide once I get close to the bit size.............hopefully its loose beforehand
#52
As I said on the phone Malcolm,
Once you get the area hot use that center punch and give the bolt a good smack. Then if you can get anything on it to turn it do that first. Otherwise then drill it out and use a bolt extractor while the area has been heated.
Good luck with it though. I wont be able to make it out I am afraid I got a call from a local fellow who needs me to go and inspect the brakes on his Bentley tomorrow!
#53
#55
#56
#57
Greg, it is a 1990, I dont think that it does. But I will find out tomorrow.
I did however find out that trying to get parts can only really be obtained at the dealer.
$336 for front pads, $394 per front rotor, $259 rear pads, and $375 for rear rotors. All in stock locally except for the rear rotors.
#58
#59
If not, you might want to give me a call, cause they are unlike any other normal car brake system.
Bentley, Rolls and Peugeot are about the only ones I can think of that use that setup.
The spheres are a replacement item, no more than 5 years or 30,000 miles.
#60
Major success............many thanks to all for your contributions..........Colin and Mike for there MIG welder offers and Dave for consummate words of wisdom and all others.
After periodic soaking all night in penetrating oil I tried in vain to grab the FBB but it was a non starter. Putting a new point on my punch I center punched the FBB very close to centre. Applying heat with a handheld butane torch I got the surronding block to the 'boil spit test', centre punched again then started to drill. 1st drill was a 7/64 LH bit which took a good amount of time to get through the FBB. Afer that it was a matter of progressively bigger bits until I got very close to the original threads then it was a matter of a sharp pic and then ran a tap through the threads...........c'est fini.
I should add I used the old WP as a drill guide once I got to a bigger drill bit size.
ps..........how did Bentlys get into this thread? I guess Andrew was busy and missed the opp. to introduce Llamas
Again thx to all and hope this help with anyone who has similar issue.
