928 Forum 1978-1995
Sponsored by: 928 Specialists
SOS...HELP...HELP...Bill Ball is in trouble!!!!!!!!!!!!!!!!!!!!
Old 07-30-2009, 03:58 AM
  #31
Pagnobito
Pagnobito's Avatar
Wow, that damage looks nasty, but good job the object went under the car and not through the window!
Old 07-30-2009, 04:05 AM
  #32
Bill Ball
Under the Lift
Bill Ball's Avatar
Special thanks to Darien Nunn, Dr. Bob, Kevin Flynn and Jim Corenman!!! Everything is roadworthy again.
The short story is I ran over what Kevin surmised must have been a 3 1/2" round, maybe 18" long steel pipe, judging by the impressions on my completely destroyed rear driver side exhaust (Jim Corenman's pic clearly shows the round impression). Besides that damage, it mashed the shifter cable brackets on the side of the tranny and mashed the cable, tore up the bellypans and pushed up a few areas of the floor just a bit.
I really didn't get a good look at the object. It made one helluva racket as it tore up the underside of my car. At that moment I was sure my trip was over. There I was, 100 miles east of Tucson in 105F heat figuring my oil pan had to be broken open from the feel of the impact. I killed the motor and coasted to a stop. A quick look under the car showed no oil pool or trail behind the car but just a damaged rear exhaust hanging down and almost torn off.
I tried to start the car but I could not get the shifter out of drive. I figured part of the object must have jammed between the torque tube and the bottom shifter. A bit hard to imagine, but possible. So, using the tools in the factory tool kit, the only tools I had with me, I removed the shift console to free it up. That didn't help. So, I got under the car again and discovered the object had pushed the mangled exhaust and the heatshield up against the tranny. I undid what remained of the exhaust, threw it in the hatch and tugged on the heatshield a bit. The shifter was stiff but it moved. The car started and ran OK. All of the rubber exhaust hangers were broken, so the exhaust and RMB dangled close to the ground. With the loud rumble of no driver side exhaust cat-back and the low-hanging pipe I felt very ricer, but the car ran and I found 4th gear eventually.
A few hours after I reached Alamogordo, Darien and the boys had a "new" 86 driver side exhaust mounted, which doesn't quite reach the RMB but is otherwise very nice. Darien had 4 rubber hangers too. The banged up heatshield was banged back into reasonable shape. We did our best to fix the mashed shifter cable but it is still stiff but workable for now.
So, I again am one lucky dude. The pipe missed all the vital organs. It travelled a few inches to the left of the tranny. Judging by the damage to the exhaust, it would have torn off the tranny pan and probably destroyed the valve body had it been a few inches to the right.
Old 07-30-2009, 07:38 AM
  #33
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,455 Likes on 1,378 Posts
Bill Glad your back on the road , Sorry you had to replace that hi milage pipe it was working so well.
If you need any more assistance i will lend a hand, Stan
Old 07-30-2009, 08:06 AM
  #34
SeanR
SeanR's Avatar
That is an example of why this community is so great. If roger doesn't have the exhaust, I've not an extra set of the larger resonators/pipes that I've not installed on my car yet.
Old 07-30-2009, 08:12 AM
  #35
Gretch
Range Master
Pepsie Lite
Gretch's Avatar
Received 1,235 Likes on 755 Posts
So Bill, drive AROUND that stuff in the future, ok.......??????????
Glad to hear it all worked out!
Old 07-30-2009, 09:08 AM
  #36
sharknoob
sharknoob's Avatar
Be glad that didn't come right up into the seat bottom...... Glad to hear your OK
Old 07-30-2009, 09:33 AM
  #37
heinrich
928 Collector
heinrich's Avatar
Bill I'm glad you're OK. When Darien called, it sounded like you would be, we knew he had the extra mid-muffler.
Old 07-30-2009, 10:26 AM
  #38
Imo000
Captain Obvious
Super User
Imo000's Avatar
well done!
Old 07-30-2009, 11:35 AM
  #39
ew928
Owns the Streets
Needs Camber
ew928's Avatar
Team of Surgeons at Work.
Great job on the Franken Exhaust.
Old 07-30-2009, 12:23 PM
  #40
Randy V
Randy V's Avatar
Keep on rockin', Bill!
Old 07-30-2009, 12:56 PM
  #41
Mako 928
Mako 928's Avatar
Bill
Glad to hear you are all right. You have way to many "Helpin others" CARma points to keep you stranded in the desert.
Great to see "the list" come to the rescue.
I have a feeling that with so many people comming from all over to OCIC that this will be one of many stories of 928ers helpin each other out.
Old 07-30-2009, 05:09 PM
  #42
pcar928fan
pcar928fan's Avatar
Jeff,
FULL marks on your avatar there! NICE!
BB glad you are back up and running and little worse for the wear! Have a safer journey the rest of the way!
Old 07-30-2009, 05:54 PM
  #43
86'928S MeteorGrey
86'928S MeteorGrey's Avatar
Excellent news. I love how the 928 community pulls together in times of need. Brings a tear to my eye...
Old 07-30-2009, 06:02 PM
  #44
UncleMaz
UncleMaz's Avatar
+1 New to the forum, the 153BB is getting a little misty as well. Very reassuring!
Old 07-30-2009, 06:19 PM
  #45
Joe '87 S4
Joe '87 S4's Avatar
Good to hear it wasn't a major disaster and Bill's back on the road.
What I'm really impressed with is how the drivers door stays open at that angle. Mine won't even stay open when the car is level.
Quick Reply: SOS...HELP...HELP...Bill Ball is in trouble!!!!!!!!!!!!!!!!!!!!
