928 Forum 1978-1995
Sponsored by: 928 Specialists
SharkTuner Mk 2
Old 10-08-2009, 03:52 PM
  #121
AO
Supercharged
AO's Avatar
Originally Posted by Bill Ball
I'm not sure I follow Andrew's idea on the firewall adjustment. I do the opposite - take as much slack out of the throttle cable as possible by screwing that adjuster out, as long as you still get the idle click reliably and the throttle seats fully when you release it. That will make the WOT come on as early as it can w/o screwing up the idle.
Bill, we might be saying the same thing. Maybe my in is your out. My point is that when I replaced my throttle cable, the replacement gave me only 1/2 the accelerator pedal travel of the other. This meant that when I had the pedal all the way down, I was only getting a little over 1/2 WOT - actual throttle, not the switch.
After adjusting this, I now get 100% WOT! (SOB is fast too! ) I thought I'd throw it out there just in case someone else had not considered adjusting their trottle cable.
Old 10-08-2009, 03:53 PM
  #122
PorKen
Inventor
PorKen's Avatar
What happened with that boost activated WOT switch from DR? I can't seem to find it, now?
Old 10-08-2009, 03:58 PM
  #123
AO
Supercharged
AO's Avatar
I'm not sure he's selling it as a separate unit. But mine's still in the car and works great!
Old 10-08-2009, 04:11 PM
  #124
Bill Ball
Under the Lift
Bill Ball's Avatar
Yes, the cable adjustment is important. Whichever way it turns, just get all the slack out with careful checking that the idle switch click is till there.
Old 10-08-2009, 04:13 PM
  #125
hans14914
hans14914's Avatar
It used to be posted on his site. I think he called it a PowerBoost module or something like that. I cant find it now either. I also dont see a separate listing for his extreme heat exchanger either.
Old 10-08-2009, 05:48 PM
  #126
worf928
worf928's Avatar
Received 1,695 Likes on 1,102 Posts
Originally Posted by John Speake
If anyone else can measure their temp 2 sensors and post the values, that would be a good cross check of that theory.
What data exactly are you looking for? I have a selection of NTC-II sensors I can measure. I assume resistance and ambient temperature?
Old 10-08-2009, 05:53 PM
  #127
John Speake
John Speake's Avatar
The resistance of the two elements relative to each other. Ambient temp is a good start. Other temps a bonus, I assume they will track.
That will tell us if my 2% matching is typical.
I also expect the absolute resistance to be in the ranges shown in the WSM.
Not desperate, we have addressed the main ST issue, but such info is useful for the general understanding of the 928's electronics. Knowledge is power !
Thanks !
Old 11-30-2009, 03:16 AM
  #128
FUSE69
FUSE69's Avatar
Hi all,
I connected up my Sharktuner for the first time this weekend, I have suspected that my Hall sensor was shot, due to a lack of around 40-50 Hp last time I had the car dyno'd....
However, the 'Ignition system monitor' shows a green light for the Hall sensor, but is red for 'Ignition retarded'....
(See screen shots below)
I've searched and read a few threads, so it seems that this is potentially some kind of intermittent error, from either the Hall sensor or knock sensors. (knock sensors replaced 2yrs ago)
Apart from checking the wiring and routing, are there any other issues that could cause this??
I haven't bothered to connect the analogue output of my WBO2 to the sharktuner yet.... but here is a shot of my WBO2 display, taken at idle (same time as pics above)
Old 11-30-2009, 03:28 AM
  #129
jcorenman
jcorenman's Avatar
Originally Posted by FUSE69
Hi all,
If you shut down the engine and restart, does it show the red "knock retard" immediately? Or later? After idling or driving or ??
John can say more but I think you are correct about it being an intermittent of some sort. I know that an intermittent knock-sensor fault will put it into retard-mode until the ignition is shut off, not sure about a hall-sensor fault.
Old 11-30-2009, 03:55 AM
  #130
FUSE69
FUSE69's Avatar
I only reversed the car out of the garage and let it idle, so I haven't as yet put the engine under any load with the sharktuner connected.
I tried shutting down and restarting a few times, but the red 'ignition retarded' shows up immediately.
Though as you can see in the screen shot, it doesn't show any knock retard per cylinder.... should it show the amount of retard, under 'knock retard'??
Old 11-30-2009, 05:59 AM
  #131
John Speake
Hi Ben
Yes, it would normally show the retard as 6deg on all cylinders on the display at the bottom of the EZK System Monitor screen.
Suggest you try datalogging as you start the car. There may be a clue there. But an intermittant is a reasonable assumption.
Try a short test drive, if poossible, also datalogging.
Old 11-30-2009, 01:10 PM
  #132
FUSE69
FUSE69's Avatar
Thanks for the input.
I'll have a bit of a 'dig around' and see what I come up with...
Unfortunatly it will have to wait until the weekend though...
Old 11-30-2009, 01:16 PM
  #133
John Speake
OK..... when I tested your EZK with your ST2 on the bench there was certainly no spurious "retard" red light showing.....
You could also try a battery disconnect, for a few seconds.
Old 11-30-2009, 01:28 PM
  #134
Tony
Tony's Avatar
this is exactly what mine did. I had done some rewiring on the hall sensor conenctor when i pulled my motor out last summer. I failed to secure the wiring properly when i put it all back in. Over time the wiring dangled and rubbed on the exhaust/heat sheild exposing the wires and giving me 6' retard on all cylinders under higher load conditions. It was acutally a PITA to discover. I just happend to looked in with a flas hlight and saw it. The connector was fine, it was just the wiring i added from it.
Old 11-30-2009, 01:31 PM
  #135
John Speake
A yes ! I remember now, Tony. Good call.....
Quick Reply: SharkTuner Mk 2
