Why when you touch one thing, ? *UPDATE* It's Running!!!!!!
Today, decided to replace fuel filter, short hose from tank to fuel pump and put in a new check valve. Simple, right?
Well, all done, go to fire up car, fuel pump is whirring nicely, no fuel leaks, but only about 18PSI and car won't start.
Everything was fine before I started this simple project, fuel pressure was around 40PSI.
Possible that the strainer got clogged when I drained the tank? Collapsed the strainer when tried to restart? Any other ideas?
Going to put in a new strainer, wish me luck that the old one comes out easy without messing up the tank.
Route the short hose between the tank and pump to a container with fuel in it and see if that improves your pressure. If not, don't mess with the strainer -- sometimes the threaded bung in the tank comes loose when you try to remove the strainer. Better to not touch it unless you know it's necessary.
Dave, good idea, will try that first. I wonder if the fuel pump is weak and the new check valve is causing that to show up, not enough umph from the old pump.
Try Daves idea, that will help isolate problem. The check valve only comes into play on shutdown. Its purpose is to hold fuel in lines and rail for startup. It's also possible that something got into fuel line causing regulator to be open or regulator failed. You can clamp off return line and see if pressure increases.
Craic Head
The check valve cannot be installed backwards, there is a non-threaded portion that would prevent that:
OTOH, reversed leads are possible, but wouldn't that pump fuel back into the tank?
Team Owner
if you look carefully at the pump you will see a PLUS and a MINUS nest to eash wire connection, dont over thighten the nuts you can snap off the studs
Under the Lift
Also, the wire ends are keyed (different sizes). On the external pump, the posts are different sizes. On the internal pump, the spades are different sizes. Hard to get the polarity backwards.
Haven't had a chance to troubleshoot today. The check valve can really only go in one way with feed holed inside banjo fitting. Bill is correct, the + terminal has a smaller hole/stud than the - terminal, so can't wire backwards unless on purpose. Hopefully work doesn't get in the way tomorrow so I can try a couple of different things.
Under the Lift
