928 Forum 1978-1995
Sponsored by: 928 Specialists
Oil Pan Stud Kit ?
Old 03-18-2009, 11:28 PM
jcorenman
jcorenman's Avatar
Dave, four of the short bolts (or studs) go over the cross-member for clearance, the fifth short bolt/stud goes in the left-rear corner over the starter. The oil pan has recesses in those locations.
We used Roger's stud kit, and I cut a few mm off the five studs that were going into those locations-- I didn't want to take the chance that they would bottom on the crossmember. Most of the studs screw into blind holes and bottomed at an appropriate height, I set the others to the same height (minus 3mm for the short ones). I put them in with red loctite. I'm sorry I didn't measure them but here's the pic's with and without gasket.
I tightened the pan by feel, I didn't trust the torque spec because this is a different sort of gasket-- as Roger said, you only want a small amount of compression. So I snugged them all up until the pan was firmly against the gasket, i.e. took up the "slack". Then went around twice (if I recall correctly) taking up 1/4 turn on each nut (until they "felt right").
P.S. This is Sue's GT, the S4 still needs MM/OPG.
Old 03-18-2009, 11:33 PM
Black Sea RD
Former Vendor
Black Sea RD's Avatar
Well I used the split ones, round of course! I used Roger's method of hand tightening each one by feel, going around the pan a few times. Very light torque trying not to over tighten them and squeezing the gasket out.
Cheers,
Constantine
Originally Posted by blown 87
I like the round ones
I used the wavy ones the last time I did it with bolts, but the torque figure was so little that a few backed out any way, and I should have used locktite.
I dont know how many times I went around that gasket to get a even torque.
Old 03-19-2009, 12:10 AM
ROG100
Basic Sponsor
ROG100's Avatar
Jim,
That second picture is pure 928 ****.
May I use it for customers please?
Roger
Old 03-19-2009, 12:17 AM
blown 87
Rest in Peace
blown 87's Avatar
What the real gasket needs is phenolic spacers to control the compression of the gasket and allow the bolts/nuts to reach a torque level that will not allow the bolts/nuts to back off.
just my .02$
Old 03-19-2009, 12:24 AM
ROG100
Basic Sponsor
ROG100's Avatar
that went way over my head but I am sure we can cater for your needs 8>)
Old 03-19-2009, 12:47 AM
blown 87
Rest in Peace
blown 87's Avatar
What I am talking about is some spacers that will prevent the gasket from being over tightened and will stop the pan from squeezing the gasket and let the bolts get tight.
The spacers go around the studs or bolts, all you have to do is make the holes a little bigger for the spacers to fit, and they may be big enough all ready.
I will try to find a gasket like this tomorrow and send you a picture Roger, most of the silicone gaskets are made like that now for other applications, some are even composite with a steel inner liner.
Old 03-19-2009, 01:53 AM
jcorenman
jcorenman's Avatar
Jim,
Roger
Of course! I'll send the original, it's a little bigger.
Greg has a great suggestion also with the spacers, I haven't seen that but it makes perfect sense.
Cheers,
Old 03-19-2009, 05:14 AM
Lizard928
Lizard928's Avatar
Phenolic might not be the best, but Rog if you make stainless sleeves which fit into each of the bolt holes to hold the pan the perfect distance away from the block so as to allow the bolts to be tightened further without squeezing the gasket.
Well beyond squeezing without deforming it, but still letting it seal.
Old 03-19-2009, 08:45 AM
SeanR
SeanR's Avatar
The 944 one comes with those spacers in the bolt holes, thought it was pretty nifty and wondered why the 928 doesn't have them.
As for the torque specs, I tried on a couple and it just was not worth the pain. Snug to fit, going over them a couple of times to ensure they are snug works well enough.
Old 03-19-2009, 09:24 AM
Black Sea RD
Former Vendor
Maybe the 944 ones can be used for our 928s, no need to reinvent the wheel.
I'm with Sean and Roger, snug to fit by hand understanding that too much torque is not needed for this application.
Cheers,
Constantine
Old 03-19-2009, 10:47 AM
blown 87
Rest in Peace
blown 87's Avatar
You really do not want anything steel there as a bolt spacer that can deform the block or pan, at least I have never seen one set up like that.
Old 03-19-2009, 01:54 PM
SharkSkin
SharkSkin's Avatar
Unless the spacers are somehow bonded to the gasket, I think you're going to find that issues will arise with installation. For example, if one of the spacers pinches the gasket, it's going to throw everything off. It may not be an issue for most, but IMHO it will cause some issues. YMMV.
Old 03-19-2009, 02:06 PM
DR
Rennlist Sponsor
DR's Avatar
There may be another solution, I have been planning to drive over to see Chris (RealGaskets is an hour away) concerning some other items and will discuss my idea with him.
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
Old 03-19-2009, 02:09 PM
blown 87
Rest in Peace
blown 87's Avatar
That goes with out saying, I wish I had one here that I could take a picture of, every one I have seen that had spacers they were bonded.
Man that would be a bitch trying to get them to stay upside down under a car.
Old 03-19-2009, 02:13 PM
the flyin' scotsman
the flyin' scotsman's Avatar
Lightbulb
Another example is the possibility of a spacer falling into the oil pan with horendous consequences.
Any spacer would have to 'fixed'; like the solution Porsche has with the 32v valve cover.
Quick Reply: Oil Pan Stud Kit ?
