Budget Oils.
My opinion:
Either use whatever weight-appropriate bargain brand you like of dino oil, and change it every 3k miles like everyone did in the 1950's.
or
Use the best synthetic you can locate and send it out for analysis so you actually know when it needs replacing.
or
Chronic Tool Dropper
In a year of driving, my M-1 gets a little darker than when it was put in, and uses about 1/4" on the dipstick give-or-take. I bought a bunch of the 'old' flavor M-1 and I'm just about through it. One more year to go on my stash.
If Mark says I can use Wesson Oil for my street car, I'll start looking for deals on it. How much ZDDP should the Wesson have, and is it available as a multi-grade for the cold winters we have here?
Rest in Peace
Every fall before you put your car in stoarge, take an oil sample and send it in*:
http://www.blackstone-labs.com/standard_analysis.html
$22 and you might find out there is no reason to change it next spring.
*for us crazy bastards who live in the snow belt.
If I am wrong for changing to early, what have I really lost?
If folks that change the oil every 15,000 miles are wrong, what have they lost?
Administrator - "Tyson"
To this date I have never sent in an oil sample of my own. I plan on starting this year since three of my cars didn't even reach 2k in 2008. I have a hard time believing the 9 quarts of 12 month old oil is somehow "bad". I'll find out soon enough and I'll post the results. I also tear open every oil filter.
I have never gone more than 5k miles before an oil change with my Audi, never 3k with my other cars.
This simply proved what works for one 928 is not the best idea in another.
One of these days I should install an oil cooler in my 81. It didn't even come with the factory cooler in the radiator.
Thanks for all the good information. At the last sevice an 928 independent specialist put in Castrol Magnatech 10W40 which is recommended by Castrol for the 928 and approved by Porsche. From the feedback on my original post this may not be such a good choice being a very modern oil rated APPI SM.
Having read the link to "Cam-shield" plus all manner of threads when I searched ZDDP my conclusion is that I will go with a full synthetic oil, probably 10W40 to suit the mild Scottish climate (never to hot or too cold), but also use an additive like Cam-shield to be sure the cams and followers get the right degree of protection. Does this seem like a sensible approach.
Rest in Peace
He does not feel any loyalty to Valvoline for more than a few reasons.
Obviously I could be wrong, but I would be very surprised if he was biased when talking to me.
Oil is not "just oil", Wesson comments notwithstanding. I had been running Valvoline 20-50 dino, then on one occasion couldn't find it locally. I went to an independent shop that talked me into getting CarQuest branded oil, he showed me the MSDS from Valvoline and assured me it was the same stuff. It wasn't. I lost 1-1/2 to 2 bar at idle. I changed it ASAP.
To the OP, it's not just about how much power the engine makes. You want an oil that will hold up when hot, not foam up, and will protect the flat tappets and soft rod bearings.
Rest in Peace
I worked for Valvoline for many years, the last few as a blender, not sure about CarQuest, but the Napa oil came out of the same tank as the cheapo Valvoline, it used to be called "All Climate" but that was years ago.
I used to blend about 250,000 gallons a week of All Climate in just 10w40.
No telling how many millions of gallons of motor oil I have made.
Valvoline does a huge amount of private label products, but you have to go to the Racing oils to get the good stuff from them, they do not private label it, or they did not while I was there.
Looks like the Mobil 1 EP 15W-50 is still good even with the SM rating. That's what I have been using recently.
EDIT: I just went down to Walmart and they don't have Mobil 1 EP 15W-50 anymore, only 10W-30![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Dan
'91 928GT S/C
475hp/460lb.ft
Dan
'91 928GT S/C
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
For years he recommended oils to me other than Valvoline, I worked with him for many years, plus he is a friend.
I'm just ragging you. It might all be true. It might.
Former Sponsor
Please....no!
