New Product - SHARKVENT Crankcase Ventilation System - NO more Oil in your Intake!
#32
Inventor
Dave,
Has anyone run the ProVent -> airpump -> exhaust combo for any length of time? I would like to set mine up this way, but have worried about moisture or oil (liquid/vapors) might damage the pump.
I was even going to go so far as make an air-amplifier-venturi-pipey-thing that the airpump would blow through to pull crank vapor out, while bypassing the pump (unfortunately it doesn't work piped into the exhaust). I don't need this with the ProVent?
#33
#34
Received 1,638 Likes
D.R. made the point: the standard version will do a perfectly good job. Take a look at the schematics - with the standard system (using the small orifice on the filler neck) there's no way for oil to enter the intake. All the lines that, in the stock system, lead to the throttle body's air guide are capped at one end or the other. Oil just has no way to get to the intake except back through the intake valves themselves (unlikely.)
The large neck orifice on the X-system will help prevent serious crank case pressure from forcing vapor back to the heads. I think it's total overkill (and told Dave as much
Of course, D.R's twin screw kit has the X version built-in so, I'm good
#35
Rennlist Sponsor
Funny you should mention this, I am convinced that running the air out from the Provent thru the air pump will actually make the pump last longer and run quieter. The miniscule amount of oil vapors that are in the separated air from the Provent will lube the pump internally :-).
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
![](http://www.928gt.com/images/928Specialists-COVER3-928GTcom.png)
#36
Rennlist Sponsor
Just to clarify, all of the 16V SharkVents are "X" versions. The Oil Filler Lid port we use on the 16Vers is a 1" port. This is why there is only one version for the 16V engines.
#37
#38
Rennlist Sponsor
#40
Umm.....
let's go back to talkin' about the Sharkvent.
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
#42
Rennlist Sponsor
DR
Since silly ??? are flowing...heres one I have:
So the oil return to the dipstick port is just fed by gravity...or is there a vacuum sucking it down? I'm wondering if there is any pressure at the dipstick...since if there is it won't drain back to the sump? From what I understand (limited at best) the dipstick should be neutral....assuming there is oil in the sump...so then it would be only gravity fed?
#44
Rennlist Sponsor
Hi Brian,
Not silly at all.
If you look in the photo above you will see an aluminum device mounted in the hose coming from the dipstick tube (or just above the oil pan adapter in the right photo). That is the Provent Check valve, it will not allow anything (crankcase pressure or oil) to go from the dipstick up towards the Provent. BUT when the oil drains from the ProVent the valve opens and lets the oil flow into the oil pan. Even if there is any pressure in the crankcase (there is very little since the pressure is released thru the SharkVent System) once the weight of the oil builds up it will stilll flow into the oil pan.
Even in extreme crankcase pressure situations the worse case scenario is the oil will build up a little and then drain when the throttle is lifted etc (for example, during shifts or decel), and again the weight of the oil overcomes what crankcase pressure there is.
Hope that makes sense.
Not silly at all.
#45
Okay two more ??? Why is the lower piece that goes to the filler neck different? Also the picture looks like the "standard" shark vent..not the eXtreme right?
