928 Forum 1978-1995
Sponsored by: 928 Specialists
Keyless Entry
Old Feb 22, 2009 | 10:33 AM
Hans S's Avatar
Hans S
Default Keyless Entry
I am installing a keyless entry and I wander does the 928 use a negative or positive trigger to lock/unlock.
Old Feb 22, 2009 | 01:33 PM
Stromius's Avatar
Stromius
Try this posting for a start: https://rennlist.com/forums/2628229-post20.html
Old Feb 22, 2009 | 10:16 PM
nsantolick's Avatar
nsantolick
Just found this on a site that sells all sorts of remote entry systems. Wiring charts for 928's of various years. Hope it's accurate.
http://www.commandocaralarms.com/wiring/Porsche/928/
Nick - S4
Old Feb 22, 2009 | 10:19 PM
CAShark's Avatar
CAShark
Nick - S4
Hmmm, no OB's?
Old Feb 22, 2009 | 10:44 PM
BC's Avatar
BC
Its a four wire system. Power, ground, and a yellow and green wire. One runs it one direction (the motor), and one ones it the other direction. Once one runs, it will not run again until the power is put the other wire. Hope that makes sense.
Old Feb 23, 2009 | 09:25 AM
Hans S's Avatar
Hans S
Thanks for the info, but I still don't understand if I need to configure it as a postive or negative trigger. See picture below, this is a Shemsi keyless entry
Old Feb 23, 2009 | 12:20 PM
Alan's Avatar
Alan
Electron Wrangler
The above answers miss the point...
It all depends on the year of your 928...
Alan
Old Feb 23, 2009 | 12:30 PM
Hans S's Avatar
Hans S
Hi Alan,
Its a 1992 GTS
Old Feb 23, 2009 | 12:43 PM
Alan's Avatar
Alan
Electron Wrangler
Then its a 2 wire (lock/arm & unlock/disarm) negative trigger and an easy install. The alarm module is under the passenger seat and all needed connections are right there.
No need to install any dome light circuits or ignition connections - the GTS does all these for you
Alan
Old Feb 23, 2009 | 01:25 PM
Hans S's Avatar
Hans S
Thanks Alan
Old Feb 23, 2009 | 09:07 PM
RED SHARK 1990's Avatar
RED SHARK 1990
Default ALARM WIRING
Hello ALAN do you have the wiring for the 1990s4 wiring for alarm?i am thinking of using the remote commando DE-30 for this.I am not good with wiring stuff ,but can try to find the guy to install this.Ps i am trying to bypass my drivers side lock problem here.Two birds with one stone.Thanks
Old Feb 27, 2009 | 08:35 AM
Hans S's Avatar
Hans S
I installed the keyless entry, using the information I found and I used Alan's diagram for the GTS. I have something weird. I can unlock, lock the passenger door with the remote and that works fine, dome lights go on etc., however it does not unlock / lock the driver door
If I use the key in either the driver of passenger door, it locks / unlocks boths sides as it should.
I used brown/red for arm/lock and brown/green for disarm/unlock, which should be correct based on the wiring diagram and data from the commando website
Any idea what I do wrong
Old Feb 27, 2009 | 10:29 AM
Alan's Avatar
Alan
Electron Wrangler
Hans,
Check to see the documentation on the unit and see if you can configure it for longer lock/unlock pulses - this is about the only thing that would make sense.
Red shark - I had posted years ago how to configure an '88 - '90 is the same.
Alan
Old Feb 28, 2009 | 03:23 AM
RED SHARK 1990
Default KEYLESS
Thanks ALAN is it the same one PAUL CHAMPAGNE LISTED.Thanks for the replied.
Old Mar 1, 2009 | 10:28 AM
Hans S's Avatar
Hans S
Hi Alan,
Sorry but stupid me I made the wrong observation, if I unlock the passenger door with the key the driver does not open, however when I unlock the driver door with a key the passenger door unlocks. Any thoughts on what this could.
