GTS died
#76
Under the Lift
Oh, well, back to Keith's issue. Mine is just a nuisance fault reading that doesn't seem to matter.
#79
+1 on Tony's TempII suggestion. My car would not start with a bad TempII when it was cold. When I removed the fuel pump fuse and cranked for 10 seconds or so, the car would start and actually run for like 10 seconds with no fuel pump. That's how flooded it was.
EDIT: And holy crap, this thread has over 1,700 views in just 4 days!
Dan
'91 928GT S/C 475hp/460lb.ft
Dan
#80
Interesting about the temp II sensor. I cleaned the engine on the GTS a year or two back and shorted out the sensor. Car wouldn't start. Got a new sensor and it fired back up. I thought about this the other day, but forgot to check it. I guess since it's only a year or so old, it slipped my mind. I think you can just connect the two leads together to by pass the sensor and see if it fires up.
#81
With a title like..." GTS died " you get a LOT of LOOKS !! sharks smell blood in the water from a great distance Had it been " GTS won't start " .... far fewer hits.
#83
Yes but all the PMs / e-mails from people wanting to buy wheels , body parts and engine can be distracting..... Some thought , OH NO he crashed the GTS ! others were thinking , OH BOY he crashed the GTS . So the fuel pump was bad and NOW something else ? You should probably just part it out !
#84
https://rennlist.com/forums/4283739-post87.html
Bosch "Super" R6 385
Is this the same as your recommendation, Ken?
#87
Inventor
I tracked down Keith's previous post on the plug he used to eliminate pinging on his GTS:
Keith's plugs had old european numbers? Maybe original install?
(russian plug thread w/pic)
#88
Inventor
GTS = Going To Service?
#89
Supercharged
Keith-
It's got to be a relay. You know you have fuel pressure... but we don't know of the injectors are firing. Do we know if you have spark?
We worked on a 91S4 here in the Detroit area that would sometimes start, but generally would not run. After a long and very painful search we found the kickdown relay (of all things) was the culprit. It would cut off the injectors (upon cranking) and would not start.
#90
The Bosch site only shows the following: What to do.
Bosch Platinum+4 Spark Plug 4477 WGR7DQP Do not gap. Gap is not adjustable. $6.25
Bosch PlatinumIR Fusion Spark Plug 4510 WGR7DQI Do not gap. Gap is not adjustable. $8.54
Super Class
Bosch Platinum Plus Spark Plug 4016 WR7DP+ $2.96
Bosch Platinum+2 Spark Plug 4310 WGR7DDP Do not gap. Gap is not adjustable. $4.55
Super Class
