928 Forum 1978-1995
Sponsored by: 928 Specialists
GTS died
Old 01-24-2009 | 05:10 PM
  #31
RyanPerrella's Avatar
RyanPerrella
Originally Posted by 928ntslow
Jumping the FP relay was one of the first things done, so we can all settle down over that one
To be honest, I didn't know that was the PSD pump running when the key was in #2 position...thought it was the FP.
I will monkey with the FP's today to diagnose.
ok so the pump does in fact run when you jumped it? Or you mistook the PSD pump cycling for the fuel pump?
Old 01-24-2009 | 05:11 PM
  #32
Bill Ball's Avatar
Bill Ball
Under the Lift
Originally Posted by John Speake
Be careful when jumping the fuel pump relay to get the correct pins, it is easy to damage the LH ECU if you get it wrong !
And to reduce the likelihood of inadvertent shorting, I put the jumper in 87 first, then into 30.
Old 01-24-2009 | 05:31 PM
  #33
928ntslow's Avatar
928ntslow
I pulled the outside fuel pump and threw 12v to it...nothin'. reversed the polarity...nothin". You could hear it bump/tick, but will not run.
I've never dealt with the inside pump. Is it the same procedure as noted in the WSM 20-14? Unless someone can tell me where to find it and how to check it (if necessary) before I pull it. Do I have to drop the gas tank?
Old 01-24-2009 | 05:46 PM
  #34
Black Sea RD's Avatar
Black Sea RD
Former Vendor
Hi Keith,
If you put voltage to the pump and nothing happened then you probably found your problem. Did you test that 12v was coming from the wires to the pump? That would confirm the rest of your circuit up to your pump is good and the pump was getting the voltage needed.
I replaced both pumps and had to drain and drop the gas tank to get the internal one out.
Good luck,
Constantine
Old 01-24-2009 | 05:52 PM
  #35
Mrmerlin's Avatar
Mrmerlin
Team Owner
Well you can do the tank either way, but i would remove the sender and see what the internal condition of the tank is, if it has sediment in it it would probably be better to remove it and clean the tank. Remember when refitting the fuel sender sealing nut, that you should soak the nut in boiling water for a few mins then install it. (per the WSM)
OR you can probably keep the tank in the car, however you will need it to be empty and the tank support might have to be lowered, you can try removing 2 of the bolts so it swings down a bit, this will let you get a socket on the pump and let it slide straight out.
If you can, try lightly tapping on the outside pump with the wires reversed you may dislodge the debris in the pump if it wont turn try pouring some marvel mystery oil in the inlet .
Warning dont hammer on the pump body as the magnets that are lining the inside of the housing will crack. Make sure to replace all of the sealing rings and if the short metal hose has been leaking or crimped on it would be wise to replace it now, also replace the fuel pump check valve and fuel filter.
Old 01-24-2009 | 06:02 PM
  #36
Charley B's Avatar
Charley B
Since you have the pump exposed, the hose running toward the tank from the pump goes to the in tank pump.
I just did my GTS. No reason to drop the tank. I loosened the front strap bolts and removed the back strap bolts, The strapping and outside pump and filter drop down and leave plenty of room to remove the in tank pump.
There is no check for the in tank pump since it will probably be running fine but the hose between the two halves of the pump will more than likely be shot.
It's necessay to empty the tank before removing the in tank pump.
Old 01-24-2009 | 06:36 PM
  #37
Herman K's Avatar
Herman K
Default Temp pump fix
Same symptoms car stopped suddenly. I fixed my outside pump by running a light oil through it when I had it removed from the car. It did required several bumps of reversed polarity to break it loose. I sprayed a lot of W40 into before hooking it up with hoses to a small bucket with a light oil. I did replace it with a new pump and kept the old one as a spare in the car. I found that my inside pump wasn't working due to the slide on contacts being dirty. This is about two years ago right now it appears that the outside pump start to get a whinning sound to it and I suspect the inside pump to be out of service.
Old 01-24-2009 | 07:38 PM
  #38
Black Sea RD
Former Vendor
Oopsy,
By "drop" I actually meant lowered, as Charley did in his post above. The tank straps were loosened and the tank manuevered to allow access to the internal pump.
Cheers,
Constantine
Old 01-24-2009 | 07:56 PM
  #39
IcemanG17's Avatar
IcemanG17
Keith
Glad you found it!!! Changing the external (main) pump is pretty easy...just make sure you only use those damm copper washers ONCE (ask me how I know) oh ya and don't torque too much on that bent metal pipe that goes from the pump to the filter, or it will leak (again ask me how I know)
the new pump should come with the check valve already in it, thats good too.....chances are your intank pump has the broken hose, since just about all of them do.....you don't have to drop the tank to get it out, but might want to if you need to clean it anyway?
Old 01-24-2009 | 08:02 PM
  #40
Mrmerlin's Avatar
Mrmerlin
Team Owner
Brian it sounds like you should have read my post # 36
Old 01-24-2009 | 08:05 PM
  #41
IcemanG17's Avatar
IcemanG17
Stan
Dude come on... I'm impressed, you actually think I can READ
Old 01-24-2009 | 08:54 PM
  #42
SeanR's Avatar
SeanR
The in tank pump could still be working, but the inner tube my have become seperated. make sure you check it.
Old 01-24-2009 | 09:56 PM
  #43
928ntslow's Avatar
928ntslow
Tried to "fix" the outside pump. Soaked it with WD40 and bumped it several times switching polarity. Unless this pump runs whisper quiet, it doesn't want to free up. When I switch polarity, it does bump, but that's it. Took the inner pump out and it had the separated hose syndrome, that pump works fine. I will replace the hose and put it back together and re install. I know some will say replace it, but times are tight and barfing out another $200 for that won't fly right now.
Anyway, I'll let the exterior pump soak in WD40 for a bit and try it later....maybe I'll get lucky
Anybody got a well working used pump?
Old 01-24-2009 | 11:07 PM
  #44
PorKen's Avatar
PorKen
Inventor
I have an old one from a GT that I use as a spare.
Old 01-25-2009 | 01:21 AM
  #45
928ntslow's Avatar
928ntslow
