Camshaft Selections
#61
Developer
Much easier to do something with steel valves, I achieved around 350 cfm from 39 mm intake valves at 0.500" so for all the dramas with dealing with Ti
Titanium valves are very hard on their seats, and because of this, they require more frequent valve jobs. I would not recommend Ti valves unless someone is planning on revving over 7500 or 8000 with regularity.
For most installs, the stainless valves or Iconel valves will provide better service with less maintenance over a longer time.
#63
I completely agree. Thats why I am going to the trouble of having stainless steel valves made which I think will be the go-to setup for 9 out of 10 engine builders (especially turbo applications).
did you also consider using a valve with thinner stems?
there is some flow to be gained from this.
1mm thinner valve stems will make a difference above 6500 rpms.....if you're going to the trouble of taking a fresh start on valves.
--Russ
#64
I have done testing with 41 and 39mm valves, without throuting there is little gain to be had by the bigger valves, Porsche use 41 mm head 6 mm stem on the GT3 and the valves are quite cheap straight from Porsche.
Greg
Greg
#65
Developer
So, on the engines that are targeted for applications to and under redline, we leave the valve shaft size alone. This would be the typical iconel or the new stainless steel valves we are now making.
But, for those few customers who want an engine built for high rev's where we will use the Ti valves, we neck the velve stem under the head as shown in these pictures. Then you have the benefits of valve stem diameter for valve stability and guide wear, and also the benefits of enhanved air flow at high RPM's.
The valve on the left is our Titanium intake valve, the one on the right is stock.
#66
guys, we are not talking about 10,000 rpm porsche cup engines where all of these factors could have measureable results. Even racing, we are blipping the engine to 6000rpm, not 9000rpm and the time needed to do this is pretty long realtively speaking. So, with 9,000rpm cup car engine, you might want to lighten the rotating assembly to equal what we can do in a 928 with a 28lb clutch and heavy valve train.
as far as HP gains go, again, shaving hairs. 10lbs off the clutch or flywheel, 5 grams off the valve or lifter, all would have imeasurable results. You do it, as Carl is pointing to for reliability, and this reliability will be effected in extreme rpm applications, not with our cars. we all know how many 150 to 200k engines that are out there that have only needed headgaskets after a life of abuse. Or in most racing applications,the bottom ends are built up but the heads are never touched even after many years of all out racing. (I had 105 race days and 20,000miles additional street miles on my engine and all that was needed was a little seat clean up on the heads!)
mk
mk
#67
It is best to keep in mind.....The law of diminishing returns. You quickly reach a point of good enough. Everything about what makes an engine work is a compromise. If the only "race" you plan to win is on the DYNO that is one thing but in the real world plus or minus a few HP makes little difference.
#68
Nice back cut.
#69
You mean there is little gain without also increasing the total port volume, right?
#70
[QUOTEQuote:
Greg
You mean there is little gain without also increasing the total port volume, right?[/QUOTE]
No I mean opening up around the valve seat, I didn't increase the volume of the port.
Carl you are right on the valve stem issue, also some heat is transferred from the valve to the guide, this is crictical for Ti, the valve guide material is important along with a valve that is coated on the stem so that it doesn't gall. Del West has a relatively short lasting coating on the stem as standard as most valves in Nascar are used for one race. other coating can be specified from them.
Also those triple groove stems might be a worry if you are using standard collets, who is cutting the triple grooves for you? If they are cut all at once, not many people have the correct machine unless they are in Europe. I would be interested to know.
Greg
Greg
Greg
#71
Developer
Greg - those pics are of Ti valves made to use the stock Porsche retainer. I recommend a Bead-Loc retainer instead - and on Monday I pick up a set of stainless valves made that way for my race car. I'll post a picture then. I like the Bead-loc design because it is a full radius cut and does not produce a fracture point in the valve stem.
From the Bead-loc website:
The essence of the Bead Loc® groove is its simplicity and forgiveness. The groove itself is a straight - forward .110" full radius. The contact points with a Bead Loc® radius lock are approximately 2:00 and 10:00 o’clock, not at the root of the groove. This system affords minimal vertical movement, especially when valve float is present, which means reduced erosion of the valve for enhanced service life.
#72
How much were the valves you made for your racecar?
#73
Carl, will you take early 32V (86) cores and modify them as part of this process to work in S4's, as well as the re-grind?
I saw Ken's post about producing S3 cams from S3 cores, but was wondering about S3->S4 (as I have some spare S3 cams - as yet unmodified).
#75
Just to avoid confusion, I meant your 32vS2 cam, not standard S4 profile.
Understandable if not - would be outside the scope of your current arrangement with the cam welder.
Hilton.
