928 Forum 1978-1995
Sponsored by: 928 Specialists
Engine cranks but does not start
Old 11-13-2008, 05:36 PM
  #46
Skiviking
Skiviking's Avatar
Originally Posted by Fabio421
I use a pair of needle nose plyers to pry them back.
Thanks...I will give it a try when I get home....I was hoping the caps prongs would fold back easier...maybe I'm just being to easy on them....
Old 11-14-2008, 07:20 PM
  #47
Skiviking
Skiviking's Avatar
Originally Posted by Imo000
Going from memory here: Just use a small flathead screwdrier and pry up the tabs, then simply pull the cover off. This way you will not damage anything internal in the relay.
Well Thanks for the advice.....I pulled off the cover to the relay and pinched off the contacts and it Fired right up after a couple cranks.....seems to be running fine....Many Many thanks!! Really didn't want to have to go the mechanic route....So I will order up new relays and be back in business.....Now to figure out why the rear and side running lights stay on......but thats another day..!!
Thanks Guys!!!
Old 11-15-2008, 10:24 AM
  #48
Fabio421
Man of many SIGs
Fabio421's Avatar
You're welcome and congratulations
Quick Reply: Engine cranks but does not start
