928 Forum 1978-1995
Sponsored by: 928 Specialists
Engine cranks but does not start
Old 11-08-2008, 11:52 AM
Shark Attack
Shark Attack's Avatar
Whys is everyone always all over the place on this kind of question?
1. Do you have spark?
2. Do you have fuel pressure?
Check these two things and advise please
Old 11-08-2008, 03:17 PM
no doubt
no doubt's Avatar
Talking
Not "everyone," Mr. Broadbrush Painter Dude! Post #2 gave the guy a test to check for a fuel or spark problem. It's the posts that came later that suggested throwing parts at the problem before knowing if it was fuel or spark related.
Old 11-08-2008, 07:04 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
As suggested, check the injection relay. Take the aluminium cover off the relay and squeez the contact together with your fingers. If it fires up, let it go, if then stalls, you know what the problems is. Be careful, not all relays are the same. They might look the same but internally they are different. I had this same issue with my '83.
Old 11-08-2008, 09:31 PM
Skiviking
Skiviking's Avatar
Well spent a good part of the day trying to trouble shoot the no start....Still no start....Tank full, New Battery, Switched out bad fuel pump relay...pump now humming along...Injector relayI pulled hoping to switch out...but had no spare like I thought to test with....Was sure I had one in my box of relays but was mistaken...So until I get a spare I'm dead in the water....Car turns over almost sputters to catch but as soon as the key returns to run it dies...Ignition switch is new to from Rodger@928RUS so I have ruled that out. I was searching for any signs of fried wires or wire...since when this first refused to catch there was a slight smell in the engine bay. But was unsure if it was from the multiple tries at getting it started. But couldn't find any obvious signs of anything cooked. Thanks for all the input....it is greatly appreciated...No other 928 guru's this far north....but I'll keep plugging at it with all the help from here. Tomorrows another day!
Old 11-09-2008, 12:23 AM
Fabio421
Man of many SIGs
Fabio421's Avatar
You say you have been rehabing it. What have you done since the last time it
ran?
Old 11-09-2008, 01:18 AM
Skiviking
Skiviking's Avatar
ran?
Well, It's been about 10 days since it was out on the road. While working on it this summer, I have made sure to fire it up and take it for a 1/2-1hr run every 15-20 days. Redid the calipers, Switched out the Steering wheel with a Momo & Momo hub...I did little Body work, and Reinstalling the interior from behind the fronts seats to the trunk. And getting ready to install some new speakers in the newer door panels....etc etc...Like I was saying rehabing what the PO had done and not done to it.....But it has always fired up even after 20 days..it might take a couple cranks for it to fire..but always does...or should I say did..
Old 11-09-2008, 02:50 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,434 Likes on 1,365 Posts
did you remove any ground wires in the trunk/hatch area?? There is a ground in the harness for the neutral safety switch, IIRC there must be a ground to the fuel pump with the shifter in park or neutral so try checking for a ground on pin 85 of the fuel pump relay. Pin 86 should have 12v in the start mode
Old 11-09-2008, 11:42 AM
Shark Attack
your way of checking could casue damage.
Old 11-09-2008, 11:51 AM
Skiviking
Skiviking's Avatar
Shark, who's way of checking? mine? If I have mentioned something that could damage my cpu or any other part let me know.....I want to be fixing not causing more problems...
By the way, How Erie? I was born there...have family over near Peach and and Kaukwa aves. Thanks for the tip I might be damaging something....
Old 11-09-2008, 11:53 AM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Did you try what I suggested?
Old 11-09-2008, 02:36 PM
Skiviking
Skiviking's Avatar
I have pulled that relay...but I haven't removed the aluminum cover yet....today is a work day for me..so probably won't get to that until tonite or in the next day or two when I have more time to pick up some new relays to exchange. Thanks for the tip!
Old 11-09-2008, 02:54 PM
Shark Attack
I was refurring to "No Doubt". I am not a fan of starter fluid. It can be harmful if you dont know how to use it. It can be harmful to you, your car and garage. Its just not the right way to check a 928 for issues. I am sure he meant well and I am sure some people swear by the stuff. Just not my choice of tools.
As far as Erie goes. You left.... it was a good choice.
Old 11-09-2008, 03:11 PM
no doubt
no doubt's Avatar
People fear what they don't know. In reality, starter fluid is a cheap, easy, harmless way to identify if you have a fuel or spark issue...the first step in debugging.
Your post, by the way, acted as though no one was suggesting debugging. And most weren't. Most of the posts were unclever "throw new parts at the problem" sorts of comments. Most posts; not all.
It's only when you discovered that you had painted with too large a brush regarding debugging versus throwing new parts at the problem that you decided to move the goalposts...suddenly the issue was potential harm in a test (an erroneous view, as well).
Read the warning label on your $2 can of starter fluid. It's not going to blow up your engine or intake. It's actually quite harmless.
Spray it into your intake. Does the car start with the spray? If yes, then you have just ruled out a "no spark" condition. Very useful for debugging, as well as quick, cheap, and easy.
Steering people away from starter fluid with FUD (Fear, Uncertainty, and Doubt) does a disservice to home wrenchers. Don't go there.
Old 11-09-2008, 09:51 PM
Skiviking
Skiviking's Avatar
When I got home I tried turning it over again....Fuel pump working.....but it seems like maybe the injector relay may not be working as there is no fuel smell. If the injectors were Working but no spark wouldn't I smell fuel? Just wondering....Pull coil wire off...it has spark...
Old 11-09-2008, 10:14 PM
no doubt
no doubt's Avatar
Good man! That's a good test.
Can you check the fuel pressure?
Quick Reply: Engine cranks but does not start
