928 Forum 1978-1995
Sponsored by: 928 Specialists
Fuel damper and Fuel press. regulator question on 16v
Old 09-11-2008, 10:40 AM
plastex
plastex's Avatar
Default Fuel damper and Fuel press. regulator question on 16v
Ok, I was just wondering what the fuel damper does?, and why do we need 2 fuel pressure regulators?
Also, if I go to one of the adjustable FPR, then do I need to buy 2 of them?
Thanks,
Oscar
Old 09-17-2008, 12:40 PM
plastex
plastex's Avatar
Anybody?
Old 09-17-2008, 12:44 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,221 Likes on 1,253 Posts
My first thought is, what are you trying to do? Why are you going to an adjustable FPR? What have you upgraded on the engine to need this?
Old 09-17-2008, 12:58 PM
Jadz928
Jadz928's Avatar
You only need 1 AFPR and the other 2 can be dampers. The dampers balance out the system, rail to rail (left & right)
The front damper is necessary. One of the FPRs can be removed IF you install a damper instead. Or no rear damper and the FPR centered between the rails.
What YM is your 928? Your need for an AFPR is unknown because most stock 928s don't need added FP. Usually it's a bandaid fix for something else wrong, ie bum fuel pump or clogged filter.
Some cars, like the fixed fuel map Euro sometimes need a bump in FP to avoid lean conditions. This was the case with mine. I added a AFPR after making sure everything else fuel related was up to snuff. So my Euro was naturally a little lean.
Old 09-17-2008, 01:08 PM
plastex
plastex's Avatar
I was looking into this because at some point this winter I am going to go with a Megasquirt system, and will eventually add a S/C at some point. Other cars I have worked on have had only one FPR. When I did the Megasquirt to my 911 Turbo I used an accel Adj rate FPR and it worked fine. At some point I will buy one of the Adj FPR and didn't know if I would have to have one for each side?
Thanks,
Oscar
Old 09-17-2008, 02:14 PM
hacker-pschorr
Ok, to swap down to a single FPR most people buy a used S4 dampner to replace one of the regulators.
You then have to re-do the plumbing from the single FPR to the return line but that is not a big deal.
Old 09-17-2008, 02:25 PM
Flint
Flint's Avatar
Don't suppose you (or anyone) have pictures?
Old 09-17-2008, 02:32 PM
123quattro
123quattro's Avatar
If you are converting to megasquirt why would you want an adjustable fuel pressure regulator? Just adjust the cells in the map where you need more fuel. It's much more precise that applying a single gain to your entire system.
hacker-pschorr
Of what?
Unless he wants a higher base line. The stock FP on an L-Jet car is low by today's standards.
I'm running over 100psi on my 81 when under boost.
Old 09-17-2008, 05:23 PM
Jadz928
Jadz928's Avatar
Here's what I did to plumb a single AFPR sans rear damper. The fuel feed hose hooks up directly to the elbow at the bottom of the reg.
Old 09-17-2008, 06:25 PM
toofast928
toofast928's Avatar
L Jet right?
Been their, done that. PM me with any Q.
The fuel dampner is a "shock absouber" for the fuel system. It quiets pulse noise from the fuel pump. For a SC set up it becomes a restriction.
Tony
Old 09-17-2008, 06:30 PM
Flint
Flint's Avatar
Ahhh, interesting... My AFPR looks a little different, but I imagine it could be made to work the same way. When I bought it I also bought an 24 damper but it doesn't have the same fittings.
Alas, but I hijack...
Old 09-17-2008, 07:13 PM
mark kibort
mark kibort's Avatar
Ive done this a few time. You only need one fuel regulator and just take the other regulator, that already has the return line and clamp the end shut! then, just attach the stock return line to it. If it leaks, it doesnt matter, its pointing to where it would go anyway. But, you get the idea. That eliminates the need for any new parts or fittings. the RRFR just replaces the one fuel reg. Nothing else needs to be done. Now, you have control of the system fuel pressure.
Did this exact thing on my two Ljet system cars (and Scots currently) and i worked all the way to near 300rwhp.
mk
Old 09-18-2008, 10:34 AM
123quattro
123quattro's Avatar
Of what?
The problem with upping the pressure is it really starts working the fuel pump hard and decreasing it's efficiency.
Old 09-18-2008, 10:39 AM
hacker-pschorr
We are talking about fuel here.........did you bump your head this morning?
If he is serious about these mods a new fuel pump better be on the short list. Even a stock S4 pump is rated to handle 50-70 percent more then an L-Jet car and is also a direct bolt in.
Quick Reply: Fuel damper and Fuel press. regulator question on 16v
