I went over to the Dark Side....
#61
#62
Brendan.....put down your tools and step away from those parts .....just do this " Part Number: 17800393 Price: $ 4,319.00
NEW
New High Performance 383E Stroker 350R replacement
Let's get this straight: You're looking for more power for your 1996 - 1999 Light duty truck with a 350R engine in it. GM Performance Parts has the answer for you with this new H.P. HT383E direct replacement engine. This engine is designed to replace your current 350R engine with increased horsepower and torque with out any of the hassle.
No modifications to the computer are needed. The HP HT383E a long block complete engine assembly that delivers 340 horsepower and 435 lb.-ft of torque at a value-driven price.
The bottom end has a 383 stroker forged steel crankshaft, heavy-duty rods, and cast aluminum pistons. The block is cast iron with 4-bolt min caps, and it's up to the task of making lots of power for years to come.
The brand new 383E makes a great alternative to the standard 350R engine your truck came with.
GM'S HT383E/340HP STROKER 1996-1999 REPLACEMENT ENGINE!!! ........"
Simple , easy with a two year warranty and it is ALL NEW !!!! Just think of it as a 6.4 liter stroker motor for under $4,500 I know I know ....what fun is that !
NEW
#63
I have stepped away. I will just drop off the parts at the machine shop I have used before here in San Diego for basic stuff, and hope that it will work out.
I need to focus on work because this is when it gets busy before the break point around thanksgiving. Then I can take a fresh look between TG and Xmas/New Years.
But I do want to tow the 78 up for SF2008....
