928 Forum 1978-1995
Sponsored by: 928 Specialists
Motor mounts
Old Jun 29, 2008 | 03:26 PM
Hi Ho Silver's Avatar
Hi Ho Silver
Default Motor mounts
Im going to replace my motor mounts on my 1983s, I wish Id done it while I had the engine out but never mind, I didnt realise the importance of them then, from what Ive read on here it makes a large difference, worth doing right?
Old Jun 29, 2008 | 03:35 PM
Landseer's Avatar
Landseer
Yes.
Old Jun 29, 2008 | 03:36 PM
SeanR's Avatar
SeanR
By "doing it right" doesn't mean you have to buy the most expensive parts available either.
Old Jun 29, 2008 | 04:33 PM
Hi Ho Silver
I was going to buy those ones from Roger
Old Jun 29, 2008 | 04:40 PM
SeanR's Avatar
SeanR
Then YES, you are doing it the right way.
Old Jun 29, 2008 | 04:53 PM
Landseer's Avatar
Landseer
Thats what I did, too.
84 and 86.
84 fan was contacting the lower radiator shroud.
86 was on its way.
I didn't detect a difference in vibration or feel, but know that I removed a lot of stress from the driveline with the repairs.
Old Jun 29, 2008 | 06:16 PM
Giovanni's Avatar
Giovanni
Someone has been using the search option
Old Jun 29, 2008 | 06:58 PM
Hi Ho Silver
I use it all the time, Ive just printed out Pirtle and Dwaynes procedure write ups
Old Jun 30, 2008 | 12:17 AM
Dwayne's Avatar
Dwayne
I did the same thing you did on the '84.....had the engine out - should've replaced the mounts - didn't! Then I got to replace them with the engine back in the car! But it's not too bad - can be done in a day.
It was well worth it for me - got rid of the vibration - I love it!! I liked the improvement so much, I'll be replacing the MM's on my wife's '88 later this summer - her motor mounts are transmitting vibration too.
Sounds like you're off to a good start - let us know how it goes - especially if you run into any problems.
Old Jun 30, 2008 | 05:06 AM
Hi Ho Silver
Im going to print your instructions out now, not in colour though ta
Old Jun 30, 2008 | 05:54 AM
marton's Avatar
marton
Does the 83 have hydraulic or solid mounts & are you having the sort of vibrations that result from the mounts. Are the mounts showing signs of wear or flattening?
Marton
Old Jun 30, 2008 | 06:27 AM
jon928se's Avatar
jon928se
Good point Marton
Hi Ho, you need to check that your mounts are the later (Special Porsche hydraulic collapsing version) Circular on plan version - these are the ones that Rog sells the replacements for. The earlier mount isn't circular IIRC and has a different X member and the Rog mounts won't fit.
If your car has the later mounts I think it is a fair bet that even if it has done no miles since 1983 the mounts will need replacing anyway after 25 years.
Old Jun 30, 2008 | 11:20 AM
Hi Ho Silver
Ok thanks, if I posted a photo of them would you be able to tell which ones they are?
Old Jun 30, 2008 | 11:28 AM
Hi Ho Silver
Thumbs up
Ive just had a look on PET and the 83 motor mounts are listed as hydraulic abd the part number is 928 375 039 00 and they are round in the picture so Im hoping Rogers will fit.
Old Jun 30, 2008 | 11:42 AM
ROG100's Avatar
ROG100
Basic Sponsor
83 takes the later style and mine will fit and they are $37.50 each and come with the correct hardware.
Roger
