Motor mounts
They look like the old Rockauto MM's. The pin on the bottom needs cutting off and as long as they do not slosh when shaken they should be OK
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
George Layton March 2014928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."
The oil pan gasket should definitely be done at this time. As for the steering rack, I found that most of the wetness on mine was from engine oil leaking on it and the only real issue I had with it were a couple of the bushings were shot. Since I haven't lost fluid from the rack, I left it alone.
Is there a good reason to change the MM's from the old style (square ones) to the new style (round ones) including the cross mount? I have it all out of the car now. Time for some decisionmaking.
I have found on the pre 83 cars that in most cases the original square solid mounts are still good after all these years. I see no real benefit to change the setup on the older cars.
You may need to change the additional engine shocks which I happen to sell for $75.99 each 8>)
No trimming and comes with new hardware.
Some people have reported that the stud on the bottom may be slightly longer than stock and possibly hit part of the steering rack. It may be a good idea to trim a couple of mm of the lower stud to be absolutly 100%. I never have and have had no problems. Easier to do it out of the car than in.
Chronic Tool Dropper
Roger-
Have you (or anyone else for that matter...) identified a reliable source for a hydraulic replacement for the hydraulic originals? Most of the threads about the aftermarket mounts focused on the imported mounts from Rock Auto. Is there a reliable domestic hydraulic mount that will last longer than the leaky RA gems? Mine are OK (Porsche mounts a few years in the car now...) but others ask pretty regularly. I like the hydraulic mounts so we don't need to retrofit the early $75.99-from-Roger to the later car when solid mounts are sub'd in. [shields up!]
The whole problem with the hydraulic MM's is that they leak and collapse.
Most do and some don't.
Anchor and Corteco supply a hydrauilc MM but why fit it if it is going to fail prematurly?
The difference in "feel" between solid and hydraulic is non existent so why take the chance?
Solid cannot fail - hydraulic can. Solid was used up until 83 and most are still good.
Nobody makes MM's in the USA now because of poor quality and high price.
Overseas suppliers offer much better quality at a lower price - sorry.
Seems to fit a lot of products these days 8>(
