928 Forum 1978-1995
Sponsored by: 928 Specialists
PorKensioner installation for Dummies, '90 GT edition
Old 02-26-2013, 02:40 AM
  #91
Stromius
Stromius's Avatar
Thanks Rob for keeping this updated and Ken for improving this as well!
Old 02-26-2013, 02:21 PM
  #92
PorKen
Inventor
PorKen's Avatar
Note, along with the 'dog bone' spacer to delete the tensioner arm bracket, the PKT ground kit also includes a shiny new 10mm stainless button head bolt and copper washer to replace the rusty tensioner arm bolt. (Rob.)
(Complete PKT conversions now include the updated ground system.)
Old 03-25-2013, 06:03 PM
  #93
PC-85-928S
PC-85-928S's Avatar
where is the 85/86 install for dummies edition?
Old 03-25-2013, 06:23 PM
  #94
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,728 Likes on 1,327 Posts
Given that Step 1 is 'Remove the front of the engine', the Dummies edition for 85/86 would be to buy a copy of JKelly's timing belt procedure- haven't seen him post much lately but you could PM him. It is the most comprehensive set of TB R&R instructions that exist for '85/86. Once the engine is nekkid, you can pick up with the instructions here.
Old 03-25-2013, 07:26 PM
  #95
Hilton
Hilton's Avatar
I used John Kelly's timing belt manual for my first belt job on an S4 - IIRC, they're pretty much identical to the S4's except for the tensioner arm pivot, and of course removal of the mechanical fan.
Old 03-23-2014, 12:13 AM
  #96
BC
BC's Avatar
I am doing something wrong on this 88. The belt is not slipping on easily at all with the engine at 0|T and putting the timing gears at the proper placements.
It's almost as if there is some slack missing somewhere.
I have noticed some do the install at 20 instead of 0|T
Really a struggle today.
Old 03-23-2014, 12:21 AM
  #97
PorKen
Inventor
PorKen's Avatar
Usually it's between the oil pump and the 5-8 gears.
Rotate the 5-8 gear with a wrench (retorque the bolt later) to pull up all the slack.
Old 03-23-2014, 12:27 AM
  #98
BC
BC's Avatar
The passenger side is really under tension. About 8 or more teeth. So it has to be turned and held to get the teeth on. When that is going on I have to fight with the driver side.
Old 03-23-2014, 12:29 AM
  #99
BC
BC's Avatar
Should I try at 20?
Old 03-23-2014, 12:35 AM
  #100
Lizard928
Lizard928's Avatar
BC,
Some do it at 45, not 20.
At 45, the cams notches are off 3 teeth.
Old 03-23-2014, 12:50 AM
  #101
BC
BC's Avatar
In which direction? Are the 3 teeth?
Old 03-23-2014, 01:15 AM
  #102
BC
BC's Avatar
I don't remember this problem the last two belt changes with the PK
Old 03-23-2014, 01:35 AM
  #103
BC
BC's Avatar
Nevermind I know which way the 3 teeth are
Old 05-03-2014, 07:06 PM
  #104
Andre The Giant
Andre The Giant's Avatar
Default Question
Hello, I am at this point, and am wondering which direction to rotate the crank/engine, clockwise ?
Next,install the balancer and pulleys (torque the crank bolt semi tight, maybe 60-70 ft lbs), remove the flywheel lock, then rotate the engine a few times to make sure that the balancer and cam gear timing marks line up. They did in my case, I checked 3 times over 6 rotations of the motor.
Andre
Old 05-03-2014, 07:32 PM
  #105
Rob Edwards
Archive Gatekeeper
Always and only clockwise, as you view from the front bumper. Righty tighty!
No need to torque the crank bolt, you'll be tightening it up somewhat just by rotating it to check the timing marks.
Quick Reply: PorKensioner installation for Dummies, '90 GT edition
