How can this be? No compression in all 8 cyls ?
#47
#49
#50
I did not remove the damper but I did change the outer pulley. Any chance the damper key sheared and shifted location? It would be an explaination but it seems hard to believe that could happen ?
#51
It seems that if there were holes in pistons and enough metal in the oil pan to see it, that there would have been gnashing of teeth, much grinding, or more evidence at failure for these more catastrophic events.........the solution will emerge, I'm betting on the KISS approach.
There is a small hand held camera that I have seen that is got a 20" 1/4-1/2 inch lens at the end of it that would fit down the sparkplug hole. It even is lighted....it reads out on a little 2x3" screen with a very decent TV picture. It may be worthwhile to get one ($150) and add it to the tool box. Have a peek in the cylinder holes and rule out as much of the internals as possible......it's would also be handy for checking out those pesky vacum lines under the intake and other nusiance places.
#52
Well..sort of checked. The damper and cams are still in proper time with each other. That does not mean the crank is still in proper time with the damper.
You can check this by making sure the crank is at TDC, the cam gears are on their marks and the #1 piston is at the uppermost position.
Dennis
#53
#54
#57
#58
#59
