Mark Kibort's new motor - with picture goodness
03-14-2008, 07:31 PM
there are lock notches in there.
03-14-2008, 07:37 PM
Quote:
Originally Posted by
Lizard931
Which picture. Maybe I am stupid, but I have been in a lot engine plants and I don't see a lock notch that I am used to.
03-14-2008, 07:48 PM
Go to the maker of the rods website and look at there pics. I believe they have some showing the notches there.
03-14-2008, 08:07 PM
Lizard931
Ya but I don't see them in hacker's photo's
03-14-2008, 08:34 PM
If you look through the gap in the cap and rod you can just see the notch.
The bearing locks are both on one side and the pics just happen to show the sides without the locks.
03-14-2008, 09:07 PM
RainmanRennlist Member
something beautiful about a clean engine..
v-engine noob q: are there any sort of dividers that go between the paired conrods on each journal? or can they rub eachother?
03-14-2008, 09:11 PM
AddictRennlist Member
Very nice! So what are some of the technical details? Bore, stroke, rod length, rod journal size, crank, piston & rod weights, crank manuf., that kind of stuff. It looks like the rod journal is gundrilled (?) in one photo, but solid when the crank is in the box.
03-14-2008, 10:25 PM
Rest in PeaceRennlist Member
V2Rocket_aka944
Just a layer of oil between them.
03-15-2008, 03:18 AM
only 102 mm bore????
if you were going to this much trouble-------not even close to 7 liters.
--Russ
03-15-2008, 09:15 AM
Lizard931
ok I'll take your word for it. I know they have to be there, just was wondering.
03-15-2008, 11:06 AM
largecar379
--Russ
would have been cool but probably not allowed for his class...
03-15-2008, 11:58 AM
V2Rocket_aka944
class.......? he needs class?
--Russ
03-15-2008, 02:35 PM
Class.........I don't need no stinking class!
I think its more about cylinder walls. I think i need them!
ITE is anything goes. and once you go over stock bore on a porsche, you are pretty much in the unlimited class in PCA as well.
I dont know the exact dimensions, but i thought it was over a 102 bore. after all , these are JE 968 aftermarket pistons.
Erik?
mk
largecar379
--Russ
03-15-2008, 03:31 PM
The one picture shows the box for the rings, and it says 4.085" on the label. That's about 103.8mm.
03-15-2008, 03:43 PM
largecar379
--Russ
Over ~6.5L requires replacing the cylinders completely.
