How many other 928 owners are in need of new alternator cooling ducting
#32
Received 1,694 Likes
Looks like we crashed that web site or something. I cannot get anything useful out of it.
#33
Under the Lift
[EDIT: this seems to be working: http://www.oldcarstuff.com/catalog/p...roducts_id=159 ]
#34
Under the Lift
#35
my idle is about 500rpm higher than normal , so even a 50% reduction wouldnt be that bad, would it. i mean, heck, the car only needs 10amps to run on the race track, and around 12 or 14 on the street with the stereo on. if it runs ok at 700rpm, if 1200rpm is normal idle and most of the time its running faster, is there a draw back? obviosly, im not doing it for power gains, but for alternator wear. actually, it could help the quick blip throttle response.
mk
mk
#36
Under the Lift
OK, then, there are larger alternator pulleys. Stock is about 2". If you went with 3", you probably would need a longer belt, but it would reduce the ratio from 2.5 to 1.67.
Here's a source for 2-7/16" that will fit our alternators.
http://www.alternatorparts.com/pulley_size.htm
The alternator shaft size is fairly common, but I can't locate a 3" pulley. You might contact Kenne Belle or Summit Racing. They may have something, although they primarily sell complete underdrive kits. Be sure to check clearance for a larger pulley.
#37
I went to Autozone and bought 52mm preheater hose for a carburator that goes from the bottom of old carburated air-cleaners to the exhaust manifold. It fits great, it slides in the opening at the alternator and slides in the remaining hose opening. You want some air flow not only to cool the alternator but at the front of that hose up in the fender wheel is one of your temperature sensors for your climate control. Ed
#40
Under the Lift
52mm fit? Odd, as I find 2.5" (64mm) to be snug. Hmmm... I'll go out and measure the plastic duct on the alternator. I just measured the stock hose and found it to be 2.5"
#41
Under the Lift
I went out to look this over. The plastic alternator duct, at least on my 89, is ovoid, about 2.6 inches by 2.1 outside dimensions. The official Porsche hose I have on my car appears to be 60mm (2.34 inch) ID, but the last hose I received from our most trusted 928 vendor was 2.5 inch ID. The original Porsche hose will just slip inside the new hose. However, the new 2.5 inch hose still fits perfectly snug on the duct. On the other end there is a metal band snugging it to the metal section holding the outside temp sensor for the climate control system. I think you can order either 2.5 or 2.25 inch. As reported, someone appears to have fit 52mm hose, which is 2.05 inch. I don't think that would fit very easily on my 2.1 x 2.6 duct.
#42
Location: In the boatyard installing the mast and engine, we don't need a crane, we harness the mesquito's! Yeah!
1 Post
It may not be Guicci - BUT - I stuck a Delco on the OB and used stainless screen to keep out the small stones - just like we use on boats. I drove through the rain, I heard from a friend that you can drive pretty fast too. I never exceed the limit personally - and 6 inches of water (slowly) in the street today. I'm not to worried about it, the car did fine. In todays world - I buy NEW Delco 110 amp alternators for <$40... You can even set the cars up with 110 SI's (self exciting one wire) for $45. I have two Bosch alternators I rebuilt - sitting in the garage - I don't think they will see the car again
You can buy Delco's at the auto store gauranteed forever for <$50 - there isn't a high mark up on alternators any more!
I know there is a thread on this somewhere - cross fit 80's Chebbies
#44
Archive Gatekeeper
Turns out I bought my ducting in August 2006, the old URL I posted is out of date. For those looking for the 2.5" ducting, it's here:
http://www.oldbuickparts.com/commerc...oducts_id=7278
#45
I tried the local Autozone, O'Riellys and advance auto parts and nothing remotely similiar.
I will try another place locally but then i will just order it by phone
