It's 928 Trivia Day!
#61
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
Here's a good one for you guys. What fuel system did the original prototype 928s run, but was disgarded for CIS in the production version?
The first generation 928 prototypes utilized a 4-barrel carbuerator that powered the 5.0L 300HP Engine with an electric fuel pump. The technology in Bosch K-Jetronic injection deemed carbueration obsolete and Porsche scrapped the idea of usinga carbuerator.
Because of the Arab Oil Embargo and its heavy impact on the world's economics, Ernst Fuhrmann and his design team had agreed to detune the original 928 prototype for production by decreasing the bore to make the final displacement of the engine 4.5L and 220 HP for it's release to the public in 1977. They felt that this would increase the reliability and fuel economy for the 928 as the general public was not looking for something that guzzled gas at the time like its American counterparts with V8s.
Damn I'm good!
Damn I'm good!
#62
928 Collector
Can rear shoulder seatbelts be installed into early 928's?
all early 928's have the threaded holes under the rear quarter tops for this purpose
Was a child seat ever produced for the 928 specifically?
yes, look in PET
yes, look in PET
#65
928 Collector
What is the most common cause of electrical problems on the 928?
The fuse panel sits under three likely rainwater leakpoints ... 1) sunroof drain ... 2) heater fan box ... 3) windshield corner seal
#67
928 Collector
928 Collector
At which point did the rear flip-up wing disappear from the 928?
1987, between VIN 1385 and VIN 1401. This is likely also where the oil squirter block disappeared
#70
928 Collector
In which direction does the fuel cooler cool fuel? Is it on a high-pressure line?
Fuel is cooled via the ac exiting the fuel rails and into the fuel tank, on a low-pressure line
#74
928 Collector
In which year were the transmission cables and lines separated from the torque tube and attached instead to the body, making it MUCH easier to drop the transmission and tube without damaging the lines?
1988
1988
