Stroker with factory ECU's-will it work?
#76
But just a little shy on the intake lift numbers though right Louie.
Hmmm, looks like I may not be the only one looking to hook up a vaccuum canister.
Gonna be a wild ride Hammer.
#78
Under the Lift
Get a new sealing ring or re-anneal the one you have. Mine did that too.
#80
Road Warrior
Thanks! good info on the injectors source. Ive heard the 24lbers could be fine for a 400rwhp 6.5 liter? at 70psi, it looks like it will work. The other factor is if I really have 70lbs at WOT at 6000rpm. i have never run the fuel pressure gauge on the dyno, just idling and reving in the driveway. I cant get the darn thing to not drip fuel (not the right seal). Its not a bad leak, but its a leak and that isnt right.
what do you all think about just taking .5mm of the base circle of the stock 86 cams??? i heard the lifters can adjust to this. I certainly wouldnt want banging lifter noise!!
mk
mk
Summit has quite a few. Price is ok.
http://store.summitracing.com/egnsea...15&Nao=0#rstop
Very impressive. Maybe this link can be helpful with injector selection.
http://www.injector.com/injectorsele...e239c17f204cbf
