can you time an 85 us car?
When I did my TB and I pulled out the timing light and i went under the hood... I got a surprise I knew about but never put togehter... 2 distributers and they dont move? How do you time this thing?
hmmm.... that may explain a lot.
I put in some RPM chips. Real ones not knock offs. and it seems like I have a loss of power between 2500-4000 RPM... if i could get this car to pull all the way through the rpm range i would be thrilled
Craic Head
Inventor
Have you checked if your air temp sensor is connected, and your octane loop is disconnected?
Sharkaholic
It is two wires with matching connectors that when connect retard the timing to allow you to run lower octane gas.
Pull the lid to the fuse box and look in the area of the brains.
