A/F Gauge and Boost gauge write up?
I bought these gauges from Carl a while back and need to hook them up. Does anybody know of a write up on installing them I also have the A piller pod for the gauge's.
Cliff
87 $4 Murf # 44
Cliff
87 $4 Murf # 44
What kind of A/F gauge is it, how many wires coming out of it? Most of them tap off of the O2 sensor, with a seperate power line and maybe a dimming circuit when your lights are on (makes it dimmer at night).
I have an "Arm1" and it has 5 wires: 1. Red to the ingition swi.+ lead, 2. Black to the battery neg side, 3. Orange to the o2 sensor, 4. Brown to a chassis ground near the O2 sensor, 5. White to the panel lights (+) to dim it at night.
Is the boost gauge also a vacuum gauge? Even if it's not I would think it just plugs into one of the manifold ports (vacuum connection) from the boosted part of the intake manifold. (Just a guess on my part as I have no personal experience with bossted engines.)
Jim Mayzurk
93 GTS 5-spd
Jim Mayzurk
93 GTS 5-spd
Here's the website for manufacturer of the gauges Carl sells. Just look up your model number and you should be good to go.
http://www.nordskogperformance.com/t...structions.htm
